Hello all I'm one of the volunteers over at the Large Scale Systems Museum. We're currently doing some work on a Tektronix 4054 and the problem seems to be the flood gun voltage. The voltage at the test point TP91 starts out within spec but quickly falls to around 55 volts within a few seconds. This circuit is fed from the +290 and +175 rail voltages through a series of transistors. Something is loading down the +175 rail because like the test point voltage it starts out good but quickly falls. I measured the current through the fuse and it went to a few hundred mA before I shut it off. Has anyone encountered a similar problem or perhaps have some insight? Thanks.
