billdeg
Technician
Attempting to follow directions here:
http://retrocmp.com/how-tos/using-pdp-11-diagnostics/227-pdp-11-diagnostics-running-them
...to load BASIC into PDP 11/40 with 16K RAM. I can boot up to an @ prompt using CONSOLE ROM of M9312. System seems stable.
Here is the process I am following, what am I doing wrong?
1) got a copy of DEC-11-AJPB-PB.ptap
2) opened MEMORY LOADER. I *think* and here is where I must be wrong... load
start address 000
end address 17464
entry address 016104
3) LOAD, DEPOSIT ALL, VERIFY ALL - all works. I can see the tape values depositing into their respective RAM address. I can verify 100% addresses match what should be in RAM, from the address I used as the start address in 2) above.
4) Still within the PDPGUI program I opened EXECUTION CONTROL window
start program counter 000
hit RESET and START
5) It's supposed (I think) to go into BASIC...but nothing happens, I have to reset the system from the front panel.
I have tried various combinations of start program counter and other addresses, nothing works.
Note I can load BASIC from a regular teletype, but I am not getting why PDPGUI will not load a tape. Maybe I don't understand, am I supposed to load the absolute loader and then the absolute loader actually loads the tape? Am I mistakenly assuming that this step is not needed. Obviously when I load a program from papertape I have to load the bootstrap loader, then the absolute loader, then the absolute tape.
Sorry to be dense....
start address 000
end address 17464
hit RESET and START
