Hi All;
Bill, Congratulations, I hope You had A good night's sleep, once You Found the problem and fixed it..
Yesterday, was a Hard Day's Night for many of us..
Dave, Thank for Explaining things so well..
Dave, I am still not so sure that You can't use some of Your MOS Memory or Core Boards, BUT, I will wait until You have a full List of all of Your MotherBoards and a full List of all of Your Boards and Maybe some Pictures as well, before I say any more.. Your there and I am not there..
"" I will 100% resist the temptation to change anything though until I know what the configuration of my machine will be. ""
I need that kind of Resistance.. Thanks Dave..
"" Marty - are you having problems running my test code as well? ""
I don't know for sure, If I am or if it's because the switches function differently..
later, after I get back from my Thursday morning Bible Study, (somewhere about 9:00 to 10:00 my time) I will give You more Details, and try to Run Your Programs and give You some Results..
But, here is an Example, Putting Zero's at '200 to '210..
I have Address Load at '200, Halt switch is Down (halted), I press Start.. I have bit 7 led on and nothing else.. All the Address light light up for a second, then all go out, except for bit 7 ('200), and all of the DATA lights are on..
I Re-press the Address Load switch bit seven stays on, and all of the Data lights go out.. Halt switch is Down, I press Continue..
Address light bit 7 and bit 1 come on a '202.. and all of the Data lights come on.. I press Continue again and I get a '204..
I have copied over to my site what was here..
I have copied the above over on to my site, so as not to Steal Bill's Thunder..
Congratulations, again , Bill..
THANK YOU Marty
