What I meant was that if the OP is to find value in the old 11/730 it will probably be the things that make it different than other machines, and I was actually asking to find out what the OP liked about the 11/730. If you just want to run BSD then why on a VAX (unless you have nostalgia for a specific version running on a VAX)? For me, the essence of VAX-itude has always been that it ran VMS...
Sorry for being a bit rude, guess I didn't really get your point.
Well, the VAX-itude is not just into the OS but into the machine itself. Personally, I think there are three major things you can consider into a vintage system (in scrambled order):
1. Aestethical condition: the machine is better if it's good looking, since it makes a nice display in your house.
2. Hardware: the machine must be fully usable with whatever OS it was intended to be originally shipped, and maybe even more. If it's not working, it must be serviceable. Else there is no fun at all.
3. Software: you must be able to boot something on the machine, else it's pretty useless.
If you just want a VAX (any VAX)
check this out. I have no knowledge of or relationship to the vendor. There are many more out there.
I have the MicroVAX3300 and the VAXStation3100, it's enough for me right now :D
Nothing. I went through my junk box and found enough working parts to build a 486 system that could run BSD. I tested some current software I've been using and it will compile and run on the 486 (BTW - the C compiler on FreeBSD 4.x and earlier won't do -std=c99). But it is too slow for me to enjoy using it at this point (It was great back in the day, though). I only brought it up because I thought it made a comparison that many could relate to. And I do have a Pentium. And a K6-2. And a P3, a P4 an Athlon, etc. up to some fairly recent i5 machines. I even have a couple of 386 boards which seem to more or less work (do you want one?).
I built a Socket 7 Pentium MMX-based cheapo terminal system wich directly boots a DOS diskette with Telix on it. It's the cheapest crap i have, but it works farily well.
Speaking of Intel, I have: 8086, 386, Pentium, Centrino Duo and my i7. (Nah, i'm selling Socket 7 stuff myself. I'd consider trading a Socket 7 board for a 386 though
