daver2
10k Member
Ok,
So I have shamed myself into booking a half day holiday and 'smoke testing' some of the equipment I hauled back...
2 * VT525 base units. Both power up OK on 240 V and display a picture on a connected VGA monitor. Both report the message "Keyboard error" which is good, because I didn't connect a keyboard to them! One of the units has a faulty ON/OFF switch (the plastic connector between the on/off switch rod plunger and the switch itself is completely missing).
1 * TLZ06-DA DAT tape drive. Powers up OK on 240 V. Light on the drive. The cooling fan is a little noisy and dirty. I may take this apart and give it a good clean at some point in the future.
1 * DECserver 700. Powers up OK on 240 V. Lots of blinking and flashing lights . I think the 7-segment display settled on '3' which (reading from the manual I have just downloaded) means that it is trying to download the software from a remote host (that doesn't currently exist).
1 * Modem. Powers up OK on 240 V. The "9600" and "RDY" LEDs light.
1 * VAX station 4000 / 96. Powers up OK on 240 V. Fan OK. I seem to get diagnostic LEDs flashing in sequence as the firmware performs its tests. This seems to indicate that the CPU is at least OK. I suspect (from noting down some of the LED status lights that appear to persist and then checking in the manual when I got home) that this indicated that the RAM may be faulty.
This machine didn't have any disks in it when I first inspected it. I have a 19" colour monitor for it - but no cable to link the VAX station to the monitor.
I have just picked up a PS/2 keyboard from home and will attempt to get one of the VT525 units operational with the keyboard and will hook it up to the VAX station as the alternate console to see what is going on.
I do suspect (from the state of some of the machines when I inspected them) that some of the systems may have been "interfered with" shall we say...
