Success!
Today I found some time to take care about my poor Vectrex. After switching on and unplug/plug in the VDC connector to the digital board multiple times I never got the -13V available at the connector pins. It helped in the past but not anymore.
I measured +5VD and -5VDC on the major Chips without a problem though. I have checked with my scope whether there is life on the address and data Bus and yes there is! But no game sound. And no proper X,Y and Z signal.
So, I focused on the missing -13 VDC on the analog board. Input AC voltage is still good. Found AC voltage across C120. Good. Expecting some DC voltage across C121 (behind the diodes D106 and D107) but just some DC mV there. Strange. Found 2,1 VAC across D122 which is suspicious.
I turned off the unit and looked for shorts. And sure enough, capacitor C120 is shorted! De-soldered C120 and checked that cap on the bench. No short! Interesting. There is still a short across the pin holes of C120. Ok. So I de- soldered D107 and checked that one. Short! This Diode lets the voltage through in both directions.
And you know what, after replacing D107 I now get stable -13V. And the
Vectrex is working fine. Came right on.
I wonder whether D107 was only working marginally after it finally gave up the ghost. Is that possible? For some reason that short prevented the video game to boot.
I am still in doubt whether that’s all. Its too simple, isn’t it? I will see in the next days whether my Vectrex is now always booting up.
For the moment I am happy
