deramp5113
Looks like address line A4 is stuck high or stuck low. Since the monitor ROM seems to be working fine, then it's probably not a problem with the system bus or an address buffer on the ROM board (assuming the monitor ROM and the MZOS ROM are on the same board). Most likely, it's a pin/socket problem with the MZOS ROM and socket. Pull the ROM and reinsert it a few times to scrape the pins/sockets a bit. Be careful though - don't want to damage that chip - seems to be pretty rare!
If the duplicate "row" problem goes away when dumping from the monitor, then dump the ROM through the serial port again. Thanks!
Mike
Mike
