Wang OIS (Office Information Systems) 50
maxfli
What type of system is this? Anyone know what OS is run on these systems (DOS, Unix)?
From what I can glean from the documentation on bitsavers, this is a multi-user system built from multiple CPUs (mostly Z80) running in cooperation. Each workstation seems to have it's own Z80, 64K, etc. I didn't see mention of an OS, but would guess it is a proprietary Wang product. Certainly not DOS and almost-certainly not Unix. Probably not CP/M-80, either. These are essentially multiple Z80-based computers in the same cabinet, that share common I/O resources (floppy, winchester, etc), with the I/O controllers also containing Z80s to offload from the workstation units. There appears to be DMA for exchanging data between workstations and I/O controllers, and perhaps some shared-memory (probably for command/response handling). A lot of (educated) guessing, but this does not look like something you can insert an MS-DOS floppy into and boot. Without the original Wang disks, the best you could do is write an OS from scratch that is only similar to the original. Depends on the ROMs, though... if they contain the "OS" then a recovered machine might be usable.
I noticed in a picture of this system that there are DB-25 connections and BNC connections. Would dumb Terminals connect to it?
