Sorcerer Emulator .DSK Images
Yes, those Emulator files are a bit different than a typical CP/M Image as they have a 13 byte Header before
each sector's data (256 bytes) followed by a checksum byte (of the previous bytes). THANKS to Chuck(G) for
helping to locate the actual File's Layout Structure.
* There a 13 byte HEADER at the beginning of each 256 byte sector that has the
* following format:
* First byte = hex FF
* second byte = cylinder number, hex 00-4F
* third byte = sector number, hex 0-F
* fourth through thirteenth bytes = 0
* Followed by 256 bytes of sector data
* Followed by 1 byte of arithmetic checksum of the whole 13+256 bytes
* ...repeat until done...
* 270 * 16 * 77 = 332640
* 00000000 FF 00 00 00 00 00 00 00 00 00 00 00 00 CD A2 E1 ................
* 00000010 FD F9 CD 82 04 01 00 01 2A FA 04 EB D5 C5 CD 3B ........*......;
* 00000020 04 C1 D1 20 ED 04 78 FE 10 20 0E 06 00 79 B7 20 ... ..x.. ...y.
* Data at 0x000D = 0xCD is the first of the 256 bytes of RAW data.
* Remember to toss the checksum byte too.
I've conjured up a cpmtools definition for the .RAW data from these .DSK images (*.RAW) and have accessed
the files with cpmtools. My definition for the 256 Byte Sectors, 16 Sectors per Track, and 77 Tracks, with 2 Boot Tracks
follows:
# Exidy Sorcerer - SS/DD, ie: 8" - 256 x 16
# 77 tracks, 1 sides, 16 sectors/track, 256 bytes/sector
# Bytes on the media = 1*77*16*256 = 315392
# EXI2 Exidy Sorcerer - SSDD 48 tpi 8" - 256 x 16
diskdef exi2
seclen 256
tracks 77
sectrk 16
blocksize 2048
maxdir 64
datarate HD
fm YES
skew 5
# offset 8192 # 0x2000 = 8192
boottrk 2
os 2.2
end
The Directories look sane. I've extracted the BIOS.ASM and CBIOS.ASM and they also look sane.
cpmls -f exi2 -D disk1.raw
Name Bytes Recs Attr update create
ADMIN1 .WPF 2K 5
ASM .COM 10K 65
BASCNVRT.COM 4K 17
BASIC .COM 2K 11
BASIC1 .COM 10K 73
BASIC2 .COM 10K 67
BIOS .ASM 12K 92
BIOS .WPF 12K 92
CALENDAR.COM 6K 35
CBIOS .ASM 8K 55
CHESS .COM 10K 71
COPYCAT .COM 2K 9
DBS1 .WPF 4K 19
DDT .COM 6K 38
DEVCNVRT.COM 2K 11
DISKBAS .COM 4K 19
DISKCOPY.COM 4K 21
DUMP .ASM 6K 35
DUMP .COM 2K 4
ED .COM 8K 49
EXASM .COM 12K 95
EXBASIC .COM 24K 190
EXLINK .COM 6K 45
FILECOPY.COM 2K 6
FORMAT .COM 4K 19
INVADERS.COM 6K 42
LIBINDEX.COM 4K 27
LOAD .COM 2K 15
MAZE .COM 6K 35
MBASIC .COM 24K 189
MOVCPM .COM 14K 102
OBASIC .COM 20K 145
PATTERN .BAS 2K 2
PIP .COM 8K 57
PRINT .WPF 2K 11
RAY1 .WPF 2K 6
STAT .COM 4K 24
SUBMIT .COM 2K 11
SYSGEN .COM 2K 10
TOUCH .COM 6K 33
WP .COM 2K 4
WP9 .COM 6K 35
42 Files occupying 284K, 14K Free.
cpmcp -f exi2 disk1.raw 0:*.asm .
$ls -alt *.asm
-rw-r--r-- 1 larry larry 11776 Aug 11 21:36 bios.asm
-rw-r--r-- 1 larry larry 7040 Aug 11 21:36 cbios.asm
-rw-r--r-- 1 larry larry 4480 Aug 11 21:36 dump.asm
BIOS.ASM
; MDS I/O DRIVERS FOR CP/M
; (FOUR DRIVE SINGLE DENSITY VERSION)
; VERSION 1.4 JANUARY, 1978
VERS EQU 14 ;VERSION 1.4
; COPYRIGHT (C) 1978
; DIGITAL RESEARCH
; BOX 579, PACIFIC GROVE
; CALIFORNIA, 93950
TRUE EQU 0FFFFH ;VALUE OF "TRUE"
FALSE EQU NOT TRUE ;"FALSE"
SAMPLE EQU FALSE ;TRUE IF SAMPLE BIOS
IF SAMPLE
BIAS EQU 2900H ;SAMPLE PROGRAM IN 16K SYSTEM
ENDIF
IF NOT SAMPLE
BIAS EQU 0000H ;GENERATE RELOCATABLE CP/M SYSTEM
ENDIF
PATCH EQU 1500H+BIAS
ORG PATCH
CPMB EQU 000H+BIAS ;BASE OF CPM CONSOLE PROCESSOR
BDOS EQU 806H+BIAS ;BASIC DOS (RESIDENT PORTION)
CPML EQU $-CPMB ;LENGTH (IN BYTES) OF CPM SYSTEM
NSECTS EQU CPML/128 ;NUMBER OF SECTORS TO LOAD
OFFSET EQU 2 ;NUMBER OF DISK TRACKS USED BY CP/M
CDISK EQU 0004H ;ADDRESS OF LAST LOGGED DISK ON WARM START
BUFF EQU 0080H ;DEFAULT BUFFER ADDRESS
RETRY EQU 10 ;MAX RETRIES ON DISK I/O BEFORE ERROR
; PERFORM FOLLOWING FUNCTIONS
; BOOT COLD START
; WBOOT WARM START (SAVE I/O BYTE)
; (BOOT AND WBOOT ARE THE SAME FOR MDS)
; CONST CONSOLE STATUS
; REG-A = 00 IF NO CHARACTER READY
; REG-A = FF IF CHARACTER READY
; CONIN CONSOLE CHARACTER IN (RESULT IN REG-A)
; CONOUT CONSOLE CHARACTER OUT (CHAR IN REG-C)
; LIST LIST OUT (CHAR IN REG-C)
; PUNCH PUNCH OUT (CHAR IN REG-C)
; READER PAPER TAPE READER IN (RESULT TO REG-A)
; HOME MOVE TO TRACK 00
; (THE FOLLOWING CALLS SET-UP THE IO PARAMETER BLOCK FOR THE
; MDS, WHICH IS USED TO PERFORM SUBSEQUENT READS AND WRITES)
; SELDSK SELECT DISK GIVEN BY REG-C (0,1,2...)
; SETTRK SET TRACK ADDRESS (0,...76) FOR SUBSEQUENT READ/WRITE
; SETSEC SET SECTOR ADDRESS (1,...,26) FOR SUBSEQUENT READ/WRITE
; SETDMA SET SUBSEQUENT DMA ADDRESS (INITIALLY 80H)
; (READ AND WRITE ASSUME PREVIOUS CALLS TO SET UP THE IO PARAMETERS)
; READ READ TRACK/SECTOR TO PRESET DMA ADDRESS
; WRITE WRITE TRACK/SECTOR FROM PRESET DMA ADDRESS
; JUMP VECTOR FOR INDIVIUAL ROUTINES
JMP BOOT
WBOOTE: JMP WBOOT
JMP CONST
JMP CONIN
JMP CONOUT
JMP LIST
JMP PUNCH
JMP READER
JMP HOME
JMP SELDSK
JMP SETTRK
JMP SETSEC
JMP SETDMA
JMP READ
JMP WRITE
; END OF CONTROLLER - INDEPENDENT CODE, THE REMAINING SUBROUTINES
; ARE TAILORED TO THE PARTICULAR OPERATING ENVIRONMENT, AND MUST
; BE ALTERED FOR ANY SYSTEM WHICH DIFFERS FROM THE INTEL MDS.
; THE FOLLOWING CODE ASSUMES THE MDS MONITOR EXISTS AT 0F800H
; AND USES THE I/O SUBROUTINES WITHIN THE MONITOR
; WE ALSO ASSUME THE MDS SYSTEM HAS FOUR DISK DRIVES
NDISKS EQU 4 ;NUMBER OF DRIVES AVAILABLE
REVRT EQU 0FDH ;INTERRUPT REVERT PORT
INTC EQU 0FCH ;INTERRUPT MASK PORT
ICON EQU 0F3H ;INTERRUPT CONTROL PORT
INTE EQU 0111$1110B ;ENABLE RST 0(WARM BOOT), RST 7 (MONITOR)
; MDS MONITOR EQUATES
MON80 EQU 0F800H ;MDS MONITOR
RMON80 EQU 0FF0FH ;RESTART MON80 (BOOT ERROR)
CI EQU 0F803H ;CONSOLE CHARACTER TO REG-A
RI EQU 0F806H ;READER IN TO REG-A
CO EQU 0F809H ;CONSOLE CHAR FROM C TO CONSOLE OUT
PO EQU 0F80CH ;PUNCH CHAR FROM C TO PUNCH DEVICE
LO EQU 0F80FH ;LIST FROM C TO LIST DEVICE
CSTS EQU 0F812H ;CONSOLE STATUS 00/FF TO REGISTER A
; DISK PORTS AND COMMANDS
BASE EQU 78H ;BASE OF DISK COMMAND IO PORTS
DSTAT EQU BASE ;DISK STATUS (INPUT)
RTYPE EQU BASE+1 ;RESULT TYPE (INPUT)
RBYTE EQU BASE+3 ;RESULT BYTE (INPUT)
ILOW EQU BASE+1 ;IOPB LOW ADDRESS (OUTPUT)
IHIGH EQU BASE+2 ;IOPB HIGH ADDRESS (OUTPUT)
READF EQU 4H ;READ FUNCTION
WRITF EQU 6H ;WRITE FUNCTION
RECAL EQU 3H ;RECALIBRATE DRIVE
IORDY EQU 4H ;I/O FINISHED MASK
CR EQU 0DH ;CARRIAGE RETURN
LF EQU 0AH ;LINE FEED
SIGNON: ;SIGNON MESSAGE: XXK CP/M VERS Y.Y
DB CR,LF,LF
IF SAMPLE
DB '16' ;16K EXAMPLE BIOS
ENDIF
IF NOT SAMPLE
DB '00' ;MEMORY SIZE FILLED BY RELOCATOR
ENDIF
DB 'K CP/M VERS '
DB VERS/10+'0','.',VERS MOD 10+'0'
DB CR,LF,0
BOOT: ;PRINT SIGNON MESSAGE AND GO TO CCP
; (NOTE: MDS BOOT INITIALIZED IOBYTE AT 0003H)
LXI SP,BUFF+80H
LXI H,SIGNON
CALL PRMSG ;PRINT MESSAGE
XRA A ;CLEAR ACCUMULATOR
STA CDISK ;SET INITIALLY TO DISK A
JMP GOCPM ;GO TO CP/M
WBOOT:; LOADER ON TRACK 0, SECTOR 1, WHICH WILL BE SKIPPED FOR WARM
; READ CP/M FROM DISK - ASSUMING THERE IS A 128 BYTE COLD START
; START.
LXI SP,BUFF ;USING DMA - THUS 80 THRU FF AVAILABLE FOR STACK
MVI C,RETRY ;MAX RETRIES
PUSH B
WBOOT0: ;ENTER HERE ON ERROR RETRIES
LXI B,CPMB ;SET DMA ADDRESS TO START OF DISK SYSTEM
CALL SETDMA
MVI C,0 ;BOOT FROM DRIVE 0
CALL SELDSK
MVI C,0
CALL SETTRK ;START WITH TRACK 0
MVI C,2 ;START READING SECTOR 2
CALL SETSEC
; READ SECTORS, COUNT NSECTS TO ZERO
POP B ;10-ERROR COUNT
MVI B,NSECTS
RDSEC: ;READ NEXT SECTOR
PUSH B ;SAVE SECTOR COUNT
CALL READ
JNZ BOOTERR ;RETRY IF ERRORS OCCUR
LHLD IOD ;INCREMENT DMA ADDRESS
LXI D,128 ;SECTOR SIZE
DAD D ;INCREMENTED DMA ADDRESS IN HL
MOV B,H
MOV C,L ;READY FOR CALL TO SET DMA
CALL SETDMA
LDA IOS ;SECTOR NUMBER JUST READ
CPI 26 ;READ LAST SECTOR?
JC RD1
; MUST BE SECTOR 26, ZERO AND GO TO NEXT TRACK
LDA IOT ;GET TRACK TO REGISTER A
INR A
MOV C,A ;READY FOR CALL
CALL SETTRK
XRA A ;CLEAR SECTOR NUMBER
RD1: INR A ;TO NEXT SECTOR
CALL SETSEC
POP B ;RECALL SECTOR COUNT
DCR B ;DONE?
JNZ RDSEC
; DONE WITH THE LOAD, RESET DEFAULT BUFFER ADDRESS
GOCPM: ;(ENTER HERE FROM COLD START BOOT)
; ENABLE RST0 AND RST7
DI
MVI A,12H ;INITIALIZE COMMAND
OUT REVRT
XRA A
OUT INTC ;CLEARED
MVI A,INTE ;RST0 AND RST7 BITS ON
OUT INTC
XRA A
OUT ICON ;INTERRUPT CONTROL
; SET DEFAULT BUFFER ADDRESS TO 80H
LXI B,BUFF
CALL SETDMA
; RESET MONITOR ENTRY POINTS
MVI A,JMP
STA 0
LXI H,WBOOTE
SHLD 1 ;JMP WBOOT AT LOCATION 00
STA 5
LXI H,BDOS
SHLD 6 ;JMP BDOS AT LOCATION 5
STA 7*8 ;JMP TO MON80 (MAY HAVE BEEN CHANGED BY DDT)
LXI H,MON80
SHLD 7*8+1
; LEAVE IOBYTE SET
; PREVIOUSLY SELECTED DISK WAS B, SEND PARAMETER TO CPM
LDA CDISK ;LAST LOGGED DISK NUMBER
MOV C,A ;SEND TO CCP TO LOG IT IN
EI
JMP CPMB
; ERROR CONDITION OCCURRED, PRINT MESSAGE AND RETRY
BOOTERR:
POP B ;RECALL COUNTS
DCR C
JZ BOOTER0
; TRY AGAIN
PUSH B
JMP WBOOT0
BOOTER0:
; OTHERWISE TOO MANY RETRIES
LXI H,BOOTMSG
CALL PRMSG
JMP RMON80 ;MDS HARDWARE MONITOR
BOOTMSG:
DB '?BOOT',0
CONST: ;CONSOLE STATUS TO REG-A
; (EXACTLY THE SAME AS MDS CALL)
JMP CSTS
CONIN: ;CONSOLE CHARACTER TO REG-A
CALL CI
ANI 7FH ;REMOVE PARITY BIT
RET
CONOUT: ;CONSOLE CHARACTER FROM C TO CONSOLE OUT
JMP CO
LIST: ;LIST DEVICE OUT
JMP LO
PUNCH: ;PUNCH DEVICE OUT
JMP PO
READER: ;READER CHARACTER IN TO REG-A
JMP RI
HOME: ;MOVE TO HOME POSITION
; TREAT AS TRACK 00 SEEK
MVI C,0
JMP SETTRK
SELDSK: ;SELECT DISK GIVEN BY REGISTER C
; CP/M HAS CHECKED FOR DISK SELECT 0 - 3, BUT WE MAY HAVE
; A SMALLER MDS SYSTEM, SO CHECK AGAIN AND GIVE ERROR
; BY CALLING MON80
MOV A,C
CPI NDISKS ;TOO LARGE?
CNC RMON80 ;GIVES #ADDR MESSAGE AT CONSOLE
ANI 10B ;00 00 FOR DRIVE 0,1 AND 10 10 FOR DRIVE 2,3
STA DBANK ;TO SELECT DRIVE BANK
MOV A,C ;00, 01, 10, 11
ANI 1B ;MDS HAS 0,1 AT 78, 2,3 AT 88
ORA A ;RESULT 00?
JZ SETDRIVE
MVI A,00110000B ;SELECTS DRIVE 1 IN BANK
SETDRIVE:
MOV C,A ;SAVE THE FUNCTION
LXI H,IOF ;IO FUNCTION
MOV A,M
ANI 11001111B ;MASK OUT DISK NUMBER
ORA C ;MASK IN NEW DISK NUMBER
MOV M,A ;SAVE IT IN IOPB
RET
SETTRK: ;SET TRACK ADDRESS GIVEN BY C
LXI H,IOT
MOV M,C
RET
SETSEC: ;SET SECTOR NUMBER GIVEN BY C
MOV A,C ;SECTOR NUMBER TO ACCUM
STA IOS ;STORE SECTOR NUMBER TO IOPB
RET
SETDMA: ;SET DMA ADDRESS GIVEN BY REGS B,C
MOV L,C
MOV H,B
SHLD IOD
RET
READ: ;READ NEXT DISK RECORD (ASSUMING DISK/TRK/SEC/DMA SET)
MVI C,READF ;SET TO READ FUNCTION
CALL SETFUNC
CALL WAITIO ;PERFORM READ FUNCTION
RET ;MAY HAVE ERROR SET IN REG-A
WRITE: ;DISK WRITE FUNCTION
MVI C,WRITF
CALL SETFUNC ;SET TO WRITE FUNCTION
CALL WAITIO
; UTILITY SUBROUTINES
PRMSG: ;PRINT MESSAGE AT H,L TO 0
MOV A,M
ORA A ;ZERO?
RZ
; MORE TO PRINT
PUSH H
MOV C,A
CALL CONOUT
POP H
INX H
JMP PRMSG
SETFUNC:
; SET FUNCTION FOR NEXT I/O (COMMAND IN REG-C)
LXI H,IOF ;IO FUNCTION ADDRESS
MOV A,M ;GET IT TO ACCUMULATOR FOR MASKING
ANI 11111000B ;REMOVE PREVIOUS COMMAND
ORA C ;SET TO NEW COMMAND
MOV M,A ;REPLACED IN IOPB
; THE MDS-800 CONTROLLER REQUIRES DISK BANK BIT IN SECTOR BYTE
; MASK THE BIT FROM THE CURRENT I/O FUNCTION
ANI 00100000B ;MASK THE DISK SELECT BIT
LXI H,IOS ;ADDRESS THE SECTOR SELECT BYTE
ORA M ;SELECT PROPER DISK BANK
MOV M,A ;SET DISK SELECT BIT ON/OFF
RET
WAITIO:
MVI C,RETRY ;MAX RETRIES BEFORE PERM ERROR
REWAIT:
; START THE I/O FUNCTION AND WAIT FOR COMPLETION
CALL INTYPE ;IN RTYPE
CALL INBYTE ;CLEARS THE CONTROLLER
LDA DBANK ;SET BANK FLAGS
ORA A ;ZERO IF DRIVE 0,1 AND NZ IF 2,3
MVI A,IOPB AND 0FFH ;LOW ADDRESS FOR IOPB
MVI B,IOPB SHR 8 ;HIGH ADDRESS FOR IOPB
JNZ IODR1 ;DRIVE BANK 1?
OUT ILOW ;LOW ADDRESS TO CONTROLLER
MOV A,B
OUT IHIGH ;HIGH ADDRESS
JMP WAIT0 ;TO WAIT FOR COMPLETE
IODR1: ;DRIVE BANK 1
OUT ILOW+10H ;88 FOR DRIVE BANK 10
MOV A,B
OUT IHIGH+10H
WAIT0: CALL INSTAT ;WAIT FOR COMPLETION
ANI IORDY ;READY?
JZ WAIT0
; CHECK IO COMPLETION OK
CALL INTYPE ;MUST BE IO COMPLETE (00) UNLINKED
; 00 UNLINKED I/O COMPLETE, 01 LINKED I/O COMPLETE (NOT USED)
; 10 DISK STATUS CHANGED 11 (NOT USED)
CPI 10B ;READY STATUS CHANGE?
JZ WREADY
; MUST BE 00 IN THE ACCUMULATOR
ORA A
JNZ WERROR ;SOME OTHER CONDITION, RETRY
; CHECK I/O ERROR BITS
CALL INBYTE
RAL
JC WREADY ;UNIT NOT READY
RAR
ANI 11111110B ;ANY OTHER ERRORS? (DELETED DATA OK)
JNZ WERROR
; READ OR WRITE IS OK, ACCUMULATOR CONTAINS ZERO
RET
WREADY: ;NOT READY, TREAT AS ERROR FOR NOW
CALL INBYTE ;CLEAR RESULT BYTE
JMP TRYCOUNT
WERROR: ;RETURN HARDWARE MALFUNCTION (CRC, TRACK, SEEK, ETC.)
; THE MDS CONTROLLER HAS RETURNED A BIT IN EACH POSITION
; OF THE ACCUMULATOR, CORRESPONDING TO THE CONDITIONS:
; 0 - DELETED DATA (ACCEPTED AS OK ABOVE)
; 1 - CRC ERROR
; 2 - SEEK ERROR
; 3 - ADDRESS ERROR (HARDWARE MALFUNCTION)
; 4 - DATA OVER/UNDER FLOW (HARDWARE MALFUNCTION)
; 5 - WRITE PROTECT (TREATED AS NOT READY)
; 6 - WRITE ERROR (HARDWARE MALFUNCTION)
; 7 - NOT READY
; (ACCUMULATOR BITS ARE NUMBERED 7 6 5 4 3 2 1 0)
; IT MAY BE USEFUL TO FILTER OUT THE VARIOUS CONDITIONS,
; BUT WE WILL GET A PERMANENT ERROR MESSAGE IF IT IS NOT
; RECOVERABLE. IN ANY CASE, THE NOT READY CONDITION IS
; TREATED AS A SEPARATE CONDITION FOR LATER IMPROVEMENT
TRYCOUNT:
; REGISTER C CONTAINS RETRY COUNT, DECREMENT 'TIL ZERO
DCR C
JNZ REWAIT ;FOR ANOTHER TRY
; CANNOT RECOVER FROM ERROR
MVI A,1 ;ERROR CODE
RET
; INTYPE, INBYTE, INSTAT READ DRIVE BANK 00 OR 10
INTYPE: LDA DBANK
ORA A
JNZ INTYP1 ;SKIP TO BANK 10
IN RTYPE
RET
INTYP1: IN RTYPE+10H ;78 FOR 0,1 88 FOR 2,3
RET
INBYTE: LDA DBANK
ORA A
JNZ INBYT1
IN RBYTE
RET
INBYT1: IN RBYTE+10H
RET
INSTAT: LDA DBANK
ORA A
JNZ INSTA1
IN DSTAT
RET
INSTA1: IN DSTAT+10H
RET
; DATA AREAS (MUST BE IN RAM)
DBANK: DB 0 ;DISK BANK 00 IF DRIVE 0,1
; 10 IF DRIVE 2,3
IOPB: ;IO PARAMETER BLOCK
DB 80H ;NORMAL I/O OPERATION
IOF: DB READF ;IO FUNCTION, INITIAL READ
ION: DB 1 ;NUMBER OF SECTORS TO READ
IOT: DB OFFSET ;TRACK NUMBER
IOS: DB 1 ;SECTOR NUMBER
IOD: DW BUFF ;IO ADDRESS
END
Next steps are to extract all files in each *.RAW Image. Zip the Disk*.*, README.1st, Sorcerer Definitions for cpmtools & libdsk,
and any other information that should be attached.
And get those zips to Bitsavers, and whoever else is storing any Exidy Sorcerer Files.
Thanks goes to Chuck(G) for the research of the Image layout, so cpmtools could access the .RAW Images, that were created from
the 6 ???disk?.dsk images.
Larry
