Wanted: original Apple ][ floppy drive 1 & 2 and a Tandy 720k 3.5
DarthKur
Western North Carolina
I have recently rescued a Tandy 1000 TL. Everything seems to work well on it except the 720k 3.5 floppy drive. I will neither read nor format any disk put into it. It was quite dirty inside the drive. I tried to clean it to the best of my limited ability but still can not get it to work.
EDIT:
I removed the Apple ][ drives request on account that I just won a pair of them on ebay.
kb2syd
Wantage, NJ
Is the 1000 tl the one with the 26 pin floppy drive, or is it the 34 pin drive, but with no power connector. If the latter, a regular 34 pin 1.44 meg drive will work. Just make sure to disconnect the lines with the power from the floppy end. Yes, the 1.44 drive will work in place of the 720, and at 720k.
I hope this makes sense, but yes it does work.
Terry Yager
Saginaw, MI, USA 48601
Check the ribbon cable for holes between the first drive connector and the second one. If present, just about any 3.5" drive will work, if you supply power to it using a splitter from the other floppy drive's power connector. If no holes, then you may be in trouble -- don't connect that cable to a non-Tandy drive, you'll fry it! You'll have to follow kb2syd's suggestion and disconnect the power lines, if you can find the pinout for the connector. Unfortunately, Tandy seems to be of no help in that respect:
http://support.radioshack.com/produ...sp?sku_id=25-1601&Name=Tandy Desktops&Reuse=N
--T
