ElectroDude,
I am going to try attaching a jpg to this msg. The right of the diagram shows the LSI-11 CPU above the memory, then the Serial cards for VDT, TEACH, FLOPPY etc.. After that are the Parallel IO cards.
From my adventure this week, I leaned that the IO cards also send some signals back to the power boards (The next row of cards over) through the back plane. Finally the Digital Servo and Arm signal cards. these are Input cards from the Encoders and POT outputs.
If the CPU, CMOS and Serial cards work, then you should at least get the NO-VAL error on your teach pendant , or a LOAD VAL prompt on the VDT. Before VAL is loaded, the other cards are not even talked to by the computer.
You might also want to look at the second diagram. it is of the same stuff, just at a conceptual level.
