What is an 8087 -6?
Peter Holowaty
Okay, so we already have a thread going on the 8088-6. I currently have a 8087 -6 installed in my PC/XT, and I have my doubt that the -6 is an indication of frequency. These things are all over all newgroup postings, but I can't seem to determine what makes them special. Is it a low power version?
CP/M User
Back of Burke (Guday!), Australia
Re: What is an 8087 -6?
"Peter Holowaty" wrote in message:
Yes, I believe the 6 represents the Clock speed of it. 6Mhz
would be my answer. An 8087 also has a certain speed to
it because people used to say that if the speed of the
maths co-processor was slower than the CPU itself, it
would not give you the best performance. Where's if it was
faster, the co-processor would run at the speed the
computer does.
Cheers.
Erik
Site Administrator
Staff member
San Jose, CA
I'm not sure that it's a direct representation of clock speed.
I know, for instance, that the C8080-8 is a 2 MHz part. I'm not sure how/why Intel designated it -8.
Erik
MattCarp
Atlanta, Georgia (USA)
suffix depends on the part
For the 8087 the -6 suffix is the maximum clock speed. It'll work just fine in a PC/XT (4.77 MHz, of course).
For the 8080 I'm not sure what the meaning of the suffix is.
There's no standard convention, so the meaning of suffixes vary based on part.
Note that the 8087 (and 287, 387) runs at the same clock speed of the CPU, so you'll want to get a math coprocessor that operates at the same speed.
Jorg
Switzerland
Re: suffix depends on the part
AFAIK the 286 in my IBM runs at 2/3 of the 286 clock speed
Barry
8086 and 8087
8086 and 8087
The 6 and 7 have nothing to do with clock speed. The 8086 was the original Intel CPU with segmented memory so it could access more than 64k RAM.
The one IBM used in their PC was the 8088, which was basically a cheaper version of the same CPU that used an 8 bit data bus. The 8086 was a 16 bit CPU and the 8088 was sort of a 16 bit CPU and sort of an 8 bit CPU. It was slower but it was cheaper.
The 8087 isn't a CPU, it's an FPU, a Floating Point Unit that can be installed along with an 8086 or 8088 to speed up numeric processing. It was only useful with programs that were designed to use it such as some spreadsheets and most CAD programs. Since most PCs didn't have an FPU most software wasn't written to take advantage of them.
Most PCs came with a socket so you could add an 8087. But it was always an add-on.
The 486 was the first Intel CPU that included an FPU. The idea was that if the computer always had one programs would be written to take advantage of them. But manufacturers wanted to cut costs so Intel soon came out with the 486sx which left out the FPU.
The 386sx shouldn't be confused with the 486sx. The 386 never had an internal FPU. But it was a 32 bit processor and they made the sx version to cut costs, giving it a 16 bit data bus. Kind of like they did with the 8088.
Finally with the Pentium they included the FPU with every version of the processor and kept it that way.
Barry
Terry Yager
Saginaw, MI, USA 48601
Well, Intel's website was of no help. They seem to disavow any knowledge of anything before the 80186/88, which BTW, is still a current product:
Search Results for: All Products And '8087 processor'
No results matched your search.
Check the spelling, use similar words, or try a wildcard
at the end of your search string and search again.
--T
Terry Yager
Re: 8086 and 8087
Re: 8086 and 8087
Barry
Other chips of the day also had a similar (8/16-bit) archetechture, but Intel had enough savvy to promote thier 8/16-bitter as a "16-bit" chip, giving them a marketing advantage. A big contributing factor in the design of the 8088 was that it could take advantage of the base of 8-bit components which were already widely available, as well as considerably cheaper than 16-bit parts, so that the entire system could be built for less, not just the CPU. IIRC, IBM looked at other chips before deciding on the 8088, like the Motorolla 68000 and the Zylog Z8000, but decided on the 8088 only because Intel was able to meet thier needs by supplying enough chips fast enough to fit IBM's manufacturing schedule.
--T
CP/M User
Re: 8086 and 8087
Re: 8086 and 8087
That still doesn't explain what the 6 & 7 after the
CPU represent! But IIRC someone has already
explained this.
> The 8087 isn't a CPU...
Well I wasn't suggesting that the 8087 was a CPU.
However, it's true about what people have said about
the various speeds (I don't know if this applies for
the 8087 - I guess it would, but I know that the 80387
does).
> ...it's an FPU, a Floating Point Unit that can be
I sure hope you're not explaining this to me! ;-)
I do do quite a bit of work with these types of
systems, so I know! ;-)
<Yawn!! Snip!> ;-)
Cheers,
CP/M User.
Barry
I don't know anybody here and I don't know what anybody knows.
I'm just trying to answer a question.
This is fun stuff for me. If you already know about this, maybe somebody else doesn't.
I do know that when I talk with experienced programmers they hardly ever have the same experience that I had. I enjoy hearing the things they know and sharing what I know. If I already know something they share that's okay. Almost everybody knows something I don't know about and they'll get to it in time.
Barry
CP/M User
> what anybody knows.
Sorry, it's just I get a little cockey sometimes, I
wasn't sure who the respondant was ment to be.
Reason I thought it was for me, was you just
happen to start by discussion what the numbers
after the CPU represent (which is what I'm still
not sure about!) & because this is such a old
thread brought back to life, I couldn't remember
if someone had suggested it (which I thought
they did), or it was just a thought.
Well, that's another thing I was unsure. That's
perfectly fine if you're giving to the group as a
hole, which is why I'm guessing you didn't
have a respondants in question at the start.
> get to it in time.
Well, I try to agree with that, but as natural
since you're new here, I'm sorry if I came
over as hostile, sometimes I get cranky if
I see something which is in reference to
stuff I wrote with stuff I'd picked up
elsewhere. Trouble is, I pick up stuff from
all around & it get muddled sometimes. I
wasn't sure about the number after the
CPUs or FPUs.
Cheers,
CP/M User.
Barry
> over as hostile
No problem. Hostile wasn't what I thought. I was afraid I'd stepped on some toes.
Barry
CP/M User
>> over as hostile
No toes were stepped on here, as far as I can
see!
Cheers,
CP/M User.
