timbob
Hello there!
I've got myself a really nice Commodore 64-SX, and i wanted to connect it to my PC. After some searching I found a site on how to make your own Xx1541 cables (Which most of you probably already know)
So i made myself this one:
http://sta.c64.org/xm1541.html
But it doesn't work!
I checked the description and several readme files of programs like star commander and openCBM, and it should work with the internal diskdrive of the SX.
However, after plugging in the cable, the commodore freezes when turned on.
If I turn on the commodore first and then the PC, the commodore loads as normal, but after the PC has booted, some glitches appear on the commodore, and it freezes while the disk drive keeps on spinning.
If i turn on the PC first and then the commodore, the screen becomes white and the disk drive keeps on spinning too.
I checked all of the connections, multiple times. changed the diodes but still it does nothing...
Is there something wrong with my parallel port settings? Did I make the wrong cable?
Any clue on how I can fix it?
