If you don't have 720KB media, there are two square holes on the bottom of a 1.44MB floppy. One is the write-protect notch. The other indicate that the disk is 1.44MB. Try covering that hole with tape then using FORMAT A: /T:80 /N:9 to force 720KB.I have removed the compaticard.
Now it says
00640 KB OK
161-System Options Not Set-(Run SETUP)
(RESUME = "F1" KEY)
Once again, upon pressing F1, It goes straight into BASIC.
What is genuine 720KB media? Does that mean I should use other disks than 1.44 MB HD 3.5" floppys?
