Eudimorphodon
I'm not sure if this thread is the right place to report on device compatibility, but I just wanted to put it out there that I recently tested a 44-pin laptop IDE to SD converter equipped with an "FC1307A" bridge chip against my homebrew 8-bit XTIDE card and it seems to work fine with the current BIOS release. The exact device seems to be sold under a multitude of brand names, here's the Amazon listing for the one I bought.
(The card is part of a custom board set but but essentially replicates an XT-CF-lite v2b, IE, it's the 8-bit only IDE subset that doesn't work with most "real" hard drives.)
I'll probably be doing some more extensive testing on it in a few weeks after running off a board that has the 44 pin laptop header directly on it, but through a sort of Rube Goldberg cable setup I was able to fdisk/format a 2GB SD card with DOS 5.0 and it passed Check-It 3.0's disk diagnostic.
