ibmapc
I found a bug from XTIDE Universal BIOS that might cause the CF problems (actually it should cause write problems for hard disks as well). I just send a private message to ibmapc about fixed version to try.
After reflashing with test bios. XTIDE_BIOS_v1.1.2
Fdisk worked but only with the new ide_XT.bin, the new ide_XTP.bin still didn't work. Then when I attempted FORMAT C:/S, the system paused for a long time after "format complete" message and then showed "DRIVE C NOT READY"
message and after reboot the system files had not transfered. IO.SYS was the only file listed but contained zero bytes. After executing fdsik/mbr I tried another format c:/s. This time it didn't get the "drive c not ready" but still did not get system files. I then copied system files using sys command and got the IO.SYS and MSDOS.SYS but then got error stating no room for system files and COMMAND.COM contained zero bytes. So then I manually copied command.com and was able to get it to boot. But, obviously there is still something strange going on here. Very sporadic behavior.
Thanks
Greg
