glitch
Did anyone re-host this on Git or another service?
I can put it on GitHub and manage the repo, if that's desired. The XT-IDE board KiCad files will be on GitHub.
Keenerb - you need to run XTIDECFG against one of the bin files to set up the options etc before writing out to flash.
Re hosting; this has taken a back seat because the Google code site was available read-only for ages so it wasn't such an issue. The plan is to move it private hosting, which is in progress though, I'll see this gets running shortly.
Regardless, it should still be hosted on github.
I don't believe you can anymore.
TortoiseSVN reports "/svn path not found" when I try to check out https://xtideuniversalbios.googlecode.com/svn
Hosting on github was discussed a long while back and the developers didn't want it there, I can't remember why though.
It ought to be publicly available.
The software is GPLv2 licensed anyway, if it's not on github it has to be available SOMEWHERE for people who download the binaries.
Strawberry Perl is required to execute optional scripts when building XTIDE Universal BIOS. Scripts include string compression (not needed unless you modify the sources) and checksum calculation. Just run the Strawberry Perl installer with default settings.
All done!
checksum: Build/ide_tiny.bin: 3991 bytes before, 8192 bytes after
checksum: Build/ide_xt.bin: 6499 bytes before, 8192 bytes after
checksum: Build/ide_xtp.bin: 6268 bytes before, 8192 bytes after
checksum: Build/ide_at.bin: 6950 bytes before, 8192 bytes after
checksum: Build/ide_xtl.bin: 9168 bytes before, 12288 bytes after
checksum: Build/ide_xtpl.bin: 8919 bytes before, 12288 bytes after
checksum: Build/ide_atl.bin: 9788 bytes before, 12288 bytes after
checksum: Build/ide_386.bin: 7025 bytes before, 8192 bytes after
Code:C:\xt-ide\xt-ide build\source-archive_original\xtideuniversalbios\trunk\XTIDE_Universal_BIOS>mingw32-make all Deleted "(*.*)" from "Build/" * Tiny XT version "Build/ide_tiny.bin" built. * Small XT version "Build/ide_xt.bin" built. * Small XT Plus version "Build/ide_xtp.bin" built. * Small AT version "Build/ide_at.bin" built. * Small 386 version "Build/ide_386.bin" built. All small binaries built! * Large XT version "Build/ide_xtl.bin" built. * Large XT Plus version "Build/ide_xtpl.bin" built. * Large AT version "Build/ide_atl.bin" built. All large binaries built! All done! 05/13/2016 11:53 AM <DIR> . 05/13/2016 11:53 AM <DIR> .. 03/17/2016 01:03 PM <DIR> .svn 05/13/2016 11:55 AM 7,025 ide_386.bin 05/13/2016 11:55 AM 1,606,661 ide_386.lst 05/13/2016 11:55 AM 6,950 ide_at.bin 05/13/2016 11:55 AM 1,620,279 ide_at.lst 05/13/2016 11:53 AM 9,788 ide_atl.bin 05/13/2016 11:53 AM 2,017,966 ide_atl.lst 05/13/2016 11:55 AM 3,987 ide_tiny.bin 05/13/2016 11:55 AM 1,311,821 ide_tiny.lst 05/13/2016 11:55 AM 6,495 ide_xt.bin 05/13/2016 11:55 AM 1,590,468 ide_xt.lst 05/13/2016 11:53 AM 9,164 ide_xtl.bin 05/13/2016 11:53 AM 1,935,491 ide_xtl.lst 05/13/2016 11:55 AM 6,264 ide_xtp.bin 05/13/2016 11:55 AM 1,584,074 ide_xtp.lst 05/13/2016 11:53 AM 8,915 ide_xtpl.bin 05/13/2016 11:53 AM 1,929,097 ide_xtpl.lst
I haven't altered the source at all. I've installed mingw and nasm.
It's not building an 8kb/12kb file, and the files it is building aren't working on my CF adapter.
Any idea what's up?
I think the only source I have available (since I can't use SVN to check out a specific version) is simply broken...
Yes, that's the checksum byte.I notice there's a byte at the end of the bios that's always different between builds. I think that must be my problem.
It will also generate the checksum when you save the file back to disk.The wiki says you can use the xtidecfg utility to generate this checksum, but the xtidecfg program only lets you append the checksum AS part of flashing the rom.
Flash programming support is on my wishlist of features to be added to XTIDECFG. It irks me that people can't use a single tool to program all the supported hardware.HOWEVER, xtidecfg doesn't support the flash chip the xt-cf board uses, which is http://www.mouser.com/Search/Produc...virtualkey57940000virtualkey804-39SF010A7CPHE
Don't like bumping old threads, but this looks like the place I should report a minor issue I had.
AT version of XTIDE, 2.0 beta 3, Toshiba T5200/100, Conner CP30174E. IRQ 14, Block Mode enabled, LBA set to "NORMAL" manually.
Drive detected, but would not boot. Booting from floppy gave me complete/perfect access to the drive, I could copy software on to it and run it - but no boot. I repartitioned, checked it was active, formatted /S - no matter what I did I always got the "Non System Disk or Disk Error" you get from a blank floppy etc On one occasion the computer was non-responsive and required a power off afterwards.
Went back to XTIDE 1.1.5, and the drive booted straight in to MS DOS.
Same hardware was used in both scenarios. ROM address was D200 and I'd disabled EMS/Shadow in the BIOS.
Was this ever resolved?
