If you really want the Boot Menu I have attached a copy of the latest R591 IDE_XT.BIN with Boot Menu instead of the Hot Key bar, I have removed MODULE_SERIAL MODULE_SERIAL_FLOPPY.
I wouldn't bother farting about with 2.0.0b3, The XUB has come a long way since then, Lots of fixes etc. As i said before you will not be able to boot from the drive which was previously configured with 1.1.5 and then updated to a newer Revision of the XUB, The consequences are 'Missing Operating System'.
I'd re-flash the EEPROM with R591 - Reboot - FDISK / Partition and format the drive and install your OS, Fit your old drive as a slave and hopefully you will be able to copy data over to the new drive.
Another reason why I prefer DOMs over CFs.
Why did you run FDISK /MBR and then FDISK and partiton the drive. Try this, download WipeDisk and run it from a DOS boot floppy, reboot and run FDISK and partition the drive, Reboot and run FDISK again check that the drive was partitioned 2Gb or less.
Everything was working fine before you tried this BIOS upgrade, wasn't it?I actually want the CF on this machine, because it's a convenient way for me to transfer files back and forth.
.......I'll be using the CF as a transfer card to get stuff over to this PC.
Your XT has USB? Can you be more specific as to how? I use USB via DOS but even that requires a PCI card.That's what i've been doing for some time, Transferring from my XP box to my XT via CF, Though more recently it's been via USB
I wouldn't think of that as your bottleneck when you're working with a 5150!Maybe I'll just go back to 1.1.5 and deal with it not being the fastest possible.
BTW, why would you want 2 GB on a 5150? Don't you think that in 50 years it will still be 75% EMPTY? You might even have success with a smaller CF e.g., 1 GB or even much less.
Ok, I gave this a try. I ran wipedisk, then ran fdisk, partitioned for max which was 2gb, rebooted and checked partition and it was okay. Then I formatted and transferred system. Rebooted. Each time I rebooted, it detected cf okay and drive size was correct in the xtide menu.
When I tried rebooting off c:, it froze after the "Booting C>>C" message. I rebooted off floppy and ran fdisk, and the partition is gone!
Yes, it would help proportionately with the size of the drive.That's true, I probably won't notice the speed difference, except for that horrendously long time DOS takes to measure the free space on the hard drive. But I guess reducing the size of the HD would help that, too!
I was thinking a smaller CF... but it wouldn't hurt to try a smaller partition as that might be the root of all evil, here. Try something like 500 MB -- you'll never fill that up on a 5150 anyway. Or even smaller might be worthwhile. You know multiple partitions is not fatal!I didn't think reducing the size of the HD would make a difference with the problems I'm having. Are you saying get a smaller CF, or just make the partition smaller? Would that potentially fix my problem? I really don't want to buy another CF card.
