Assembly Pics
Assembly Pics
I thought I'd share my pics of the board assembly process. Click the images for a closer look. Perhaps someone would like to add these to the Wiki?
I like to start with the lowest-profile components and work toward the highest. Here is the installation of R1 through R7.
Next are the bypass caps, resistor packs, and sockets. If you bend the legs of the caps at right-angles for installation they are just shy of the socket height, so you can do the caps, resistor packs, and sockets at the same time.
After the sockets are in place, in goes the DIP switch.
The next-tallest component happens to be the LED, so it comes next.
After the LED, it's time to solder in the headers. Here, 3 of 4 are installed, leaving the 3-pin for last.
Next is the 3-pin header. I opted to use one I had on hand from Futurelec, but you can make do as shown in the next image.
If you don't have a 3-pin header on hand, cut two chunks off the remaining double-row, then cut one of those in half, for a total of 3 pins.
After the headers are finished, solder in your last (and tallest) component, C0. Then carefully install the chips in their sockets.
Once everything is installed, give the back side of the board a thorough inspection to check for cold or missing solder joints.
Assembly Pics
