hargle
Changing switches 5:8 should be harmless provided there isn't anything conflicting in memory at whatever address you land on. The memory address is simply where the ROM is placed in memory, and the mainboard BIOS will scan from C000 to F000 looking for ROMs to execute and does not effect the operation of the card. As long as there aren't any other devices using the memory you
The flash utility does expect the card to be at the default position, but you can change it easily enough in the menu settings.
You might check the XTIDE universal bios thread for more info on CF devices, and also check here in the test results section:
http://www.wiki.vintage-computer.com/index.php/XTIDE_TestResults
