hargle
The default address for the XTIDE is 300h. If you haven't changed the settings (which requires a new BIOS upgrade to tell it where the IO space is) then you should not be conflicting with the SB card. Is it maybe the MIDI stuff that is conflicting?
Anyway, there are 16 possible IO settings for the XTIDE, you should be able to find one somewhere that doesn't conflict with the SB card at all. Again, just make sure you update the BIOS at the same time as you move the IO space setting. I'd suggest keeping the SB at its factory defaults for maximum compatibility.
