NobodyIsHere
- Joined
- Dec 20, 2006
- Messages
- 2,412
Hi All,
I have a couple of questions for the XT IDE team. First, do you have an EDA like Eagle or KiCAD that supports the form factor for the XT card? KiCAD has the PC bus connector as a supported component but it still requires an "EDGES" outline of the PCB itself. Second, have you found a source for the PC card bracket connector? It has mount points which will affect the design of the PCB layout.
My suggestion is that if you already have some candidate PC cards as prototypes you could trace it to build the EDGES outline of the PCB and also determine the bracket mounting holes location.
The above things can be done by someone with no electronics experience or skills. All that would be required is getting a free EDA program and building the PCB outline. I recommend KiCAD although Eagle would work too. There are others like gEDA as well.
Next, do you have an example of the memory address decoding logic for the ROM? I see you have a ROM pin out but the most important pins (OE and CE) disappear into the bowels of an ASIC which tells you nothing about the actual actual decoding logic. It is probably pretty simple but it is important to capture the details if you'd like to add a ROM to the design. Check out the IBM technical reference for schematics to the CGA/MDA card since they contain onboard ROMs or possibly the original IBM XT hard drive controller to seperate out the address decoding logic. They have useful schematics there but there are probably others available.
Thanks and have a nice day!
Andrew Lynch
Andrew Lynch
