Mike Chambers
- Joined
- Sep 2, 2006
- Messages
- 2,655
edit: oops delete this post, mods
? 4.0*atn(1.0)
3.141593
Ok*
Case &H7C '7C JL Jb
temp16 = signext(read86(cs * 16 + ip)): StepIP 1
If (sf <> of) Then ip = ip + temp16
Case &H7D '7D JGE Jb
If (sf = of) Then ip = ip + temp16
Chuck(G) said:Mike, I'm surprised that you didn't set up a test suite for the various instructions and run it on the real hardware for verification. There are only 8 flags that really matter, so you could set up a table of 256 flag bytes and test every jump instruction, recording whether or not it actually took a
branch.
Writing verification software is a huge job when working with one of the hardware description languages (VHDL or Verliog). In fact, it's often a bigger job than writing the HDL for the implementation itself.
Good test writers are worth their weight in diamonds...
Mike, good so far. Now, crank up something like 1-2-3 and see if it holds together...
..or for something simpler, I tried running VisiCalc
However, on Mike's latest software update all I got was a blank output screen..
i just loaded up vc.com in a hex editor, and it's riddled with int 21h calls so that explains the blank screen when loaded using /com on the command line. since there's no DOS kernel loaded up that way, int 21h vector just points to 0:0.
LOL! Woohoo!! :thumbsup:Mike Chambers said:you're right, it looks like it doesnt. yay.
LOL! Woohoo!!
How's the gameplay?
You know, I'm laughing at the number of games like crossfire or moonbugs that feel like rewrites of Big 5 TRS-80 classics like Attack Force or Defense Command.
You'd think a 16 bit processor and real graphics would make these games better, not worse :D
; branch.asm - A program to test the Intel 8086 CPU's
; various conditional branching operations. Designed to
; verify corrent functionality of my 8086 PC emulator, Fake86.
org 100h
cli
push cs
pop ds
mov si, offset banner
call printmsg
testjc:
mov si, offset strjc
call printmsg
call blankflags
call setcf
jc testjc2
call fail
jmp testjnc
testjc2:
call blankflags
mov bx, offset testjnc
push bx
jc fail
pop bx ;not used, just cleaning up the stack
call pass
testjnc:
mov si, offset strjnc
call printmsg
call blankflags
jnc testjnc2
call fail
jmp testjz
testjnc2:
call blankflags
call setcf
mov bx, offset testjz
push bx
jnc fail
pop bx
call pass
testjz:
mov si, offset strjz
call printmsg
call blankflags
call setzf
jz testjz2
call fail
jmp testjnz
testjz2:
call blankflags
mov bx, offset testjnz
push bx
jz fail
pop bx
call pass
testjnz:
mov si, offset strjnz
call printmsg
call blankflags
jnz testjnz2
call fail
jmp testjs
testjnz2:
call blankflags
call setzf
mov bx, offset testjs
push bx
jnz fail
pop bx
call pass
testjs:
mov si, offset strjs
call printmsg
call blankflags
call setsf
js testjs2
call fail
jmp testjns
testjs2:
call blankflags
mov bx, offset testjns
push bx
js fail
pop bx
call pass
testjns:
mov si, offset strjns
call printmsg
call blankflags
jns testjns2
call fail
jmp testjo
testjns2:
call blankflags
call setsf
mov bx, offset testjo
push bx
jns fail
pop bx
call pass
testjo:
mov si, offset strjo
call printmsg
call blankflags
call setof
jo testjo2
call fail
jmp testjno
testjo2:
call blankflags
mov bx, offset testjno
push bx
jo fail
pop bx
call pass
testjno:
mov si, offset strjno
call printmsg
call blankflags
jno testjno2
call fail
jmp testjp
testjno2:
call blankflags
call setof
mov bx, offset testjp
push bx
jno fail
pop bx
call pass
testjp:
mov si, offset strjp
call printmsg
call blankflags
call setpf
jp testjp2
call fail
jmp testjnp
testjp2:
call blankflags
mov bx, offset testjnp
push bx
jp fail
pop bx
call pass
testjnp:
mov si, offset strjnp
call printmsg
call blankflags
jnp testjnp2
call fail
jmp testja
testjnp2:
call blankflags
call setpf
mov bx, offset testja
push bx
jnp fail
pop bx
call pass
testja:
mov si, offset strja
call printmsg
call blankflags ;case 1
ja testja2
call fail
jmp testjbe
testja2: ;case 2
call blankflags
call setcf
mov bx, offset testjbe
push bx
ja fail
pop bx
testja3:
call blankflags
call setzf
push bx
ja fail
pop bx
testja4:
call blankflags
call setcf
call setzf
push bx
ja fail
pop bx
call pass
testjbe:
mov si, offset strjbe
call printmsg
call setcf
jbe testjbe2
call fail
jmp testjg
testjbe2:
call blankflags
call setzf
jbe testjbe3
call fail
jmp testjg
testjbe3:
call blankflags
call setcf
call setzf
jbe testjbe4
call fail
jmp testjg
testjbe4:
call blankflags
mov bx, offset testjg
push bx
jbe fail
pop bx
call pass
testjg:
mov si, offset strjg
call printmsg
call blankflags
jg testjg2:
call fail
jmp testjge
testjg2:
call blankflags
call setzf
mov bx, offset testjge
push bx
jg fail
pop bx
testjg3:
call blankflags
call setsf
call setzf
push bx
jg fail
pop bx
testjg4:
call blankflags
call setof
call setzf
push bx
jg fail
pop bx
testjg5:
call blankflags
call setsf
call setof
call setzf
push bx
jg fail
pop bx
testjg6:
call blankflags
call setsf
call setof
push bx
jg pass
pop bx
call fail
testjge:
mov si, offset strjge
call printmsg
call blankflags
jge testjge2
call fail
jmp testjl
testjge2:
call blankflags
call setsf
mov bx, offset testjl
push bx
jge fail
pop bx
testjge3:
call blankflags
call setof
push bx
jge fail
pop bx
call pass
testjl:
mov si, offset strjl
call printmsg
call blankflags
call setsf
jl testjl2
call fail
jmp testjle
testjl2:
call blankflags
call setof
jl testjl3
call fail
jmp testjle
testjl3:
call blankflags
call setsf
call setof
mov bx, offset testjle
push bx
jl fail
pop bx
testjl4:
call blankflags
push bx
jl fail
pop bx
call pass
testjle:
mov si, offset strjle
call printmsg
call blankflags
call setzf
jle testjle2
call fail
jmp finished
testjle2:
call blankflags
call setsf
jle testjle3
call fail
jmp finished
testjle3:
call blankflags
call setof
jle testjle4
call fail
jmp finished
testjle4:
call blankflags
call setsf
call setzf
jle testjle5
call fail
jmp finished
testjle5:
call blankflags
call setof
call setzf
jle testjle6
call fail
jmp finished
testjle6:
call blankflags
call setsf
call setof
call setzf
jle testjle7
call fail
jmp finished
testjle7:
call blankflags
mov bx, offset finished
push bx
jle fail
call pass
finished:
ret
pass:
mov si, offset strgood
call printmsg
ret
fail:
mov si, offset strfail
call printmsg
ret
blankflags:
xor ax, ax
push ax
popf
ret
setcf:
stc
ret
setof:
pushf
pop ax
or ah, 00001000b
push ax
popf
ret
setsf:
pushf
pop ax
or al, 10000000b
push ax
popf
ret
setzf:
pushf
pop ax
or al, 01000000b
push ax
popf
ret
setpf:
pushf
pop ax
or al, 00000100b
push ax
popf
ret
printmsg:
mov ah, 0Eh
cld
lodsb
cmp al, 0
jz done
int 10h
jmp printmsg
done:
ret
banner db '8086 CPU conditional branch test utility',13,10
db 'Written on 3/4/2011 by Mike Chambers',13,10,13,10,0
strjc db 'Testing JC/JB/JNAE (jump if CF=1)... ',0
strjnc db 'Testing JNC/JNB/JAE (jump if CF=0)... ',0
strjz db 'Testing JZ/JE (jump if ZF=1)... ',0
strjnz db 'Testing JNZ/JNE (jump if ZF=0)... ',0
strjs db 'Testing JS (jump if SF=1)... ',0
strjns db 'Testing JNS (jump if SF=0)... ',0
strjo db 'Testing JO (jump if OF=1)... ',0
strjno db 'Testing JNO (jump if OF=0)... ',0
strjp db 'Testing JP/JPE (jump if PF=1)... ',0
strjnp db 'Testing JNP/JPO (jump if PF=0)... ',0
strja db 'Testing JA/JNBE (jump if CF=0 and ZF=0)... ',0
strjbe db 'Testing JBE/JNA (jump if CF=1 or ZF=1)... ',0
strjg db 'Testing JG/JNLE (jump if SF=OF and ZF=0)... ',0
strjge db 'Testing JGE/JNL (jump if SF=OF)... ',0
strjl db 'Testing JL/JNGE (jump if SF<>OF)... ',0
strjle db 'Testing JLE/JNG (jump if SF<>OF or ZF=1)... ',0
strgood db 'passed!',13,10,0
strfail db 'FAILED!',13,10,0
