Yes, they are strange...
The first one CN14 pin 1 (50 Hz) is just random mains noise pickup. Try reducing the voltage/division from 5 V/div to 1 V/div and reducing the timebase from 5 ms/div to 1 ms/div or even lower (100 us/div) etc. and see if that makes any difference. I would be expecting a much higher frequency than 50 Hz.
Also, the fact that you get different readings on CN14 pin 1 and CN15 pin 8 (two ends of a transformer winding) makes me also think that all is not well.
I can't find any datasheet on the VF display itself. It was probably a Commodore special that was made.
The measurement points are back in post #19.
I don’t see any point in doing anything else until we get the display power supply inverter working.
Post #19 contains the locations to scope (as you have done previously) we just need to ensure you have a good 0V/GND reference for the oscilloscope and play with the horizontal timebase settings.
We need to work out where the 50 Hz is coming from and see if we have a problem with the setting of the timebase to see the oscillations we are looking for.
I am not talking about the vertical v/div but the horizontal timebase ms/div or us/div...
Ok,
So back to the multimeter on dc Volts (10 Volt range) with the black lead connected to 0V/GND for all measurements.
Measure the voltage at the following points:
Junction of R71 and Q7b.
Junction of Q7e and Q8b.
Q8c.
