Just got back from my business trip late last night and just finished installing a new porch light before the forecast storm arrives!
Those readings look good to me!
Excellent...
So, what I need you to do now is to leave the circuit as it is (with the temporary resistor in place of T2 in the collector of Q8).
Whilst measuring the dc voltage across the temporary resistor, what I would like you to do is to connect a short piece of wire from 0V/GND to the base of Q7.
With the temporary shorting link not present, both transistors Q7 and Q8 will be conducting and you should find a high voltage across the temporary resistor.
With the temporary shorting link present, both transistors Q7 and Q8 should be non conducting and you should find a low voltage across the temporary resistor.
1. Are you using an analogue meter or a digital meter?
2. You do remember you are looking for a pulse as opposed to a voltage level when you make and break the Switch?
If still nothing read, can you swap your multimeter for your oscilloscope (1 Volt/division).
Ok,
With the power OFF, can you measure the resistance (with your multimeter) between transformer T1 pins 2 and 3 and between transformer T1 pins 1 and 9 please.
OK, first thing:
Can you measure the dc voltage from Q8 base to emitter when your temporary switch is both OPEN and CLOSED and post the results back please.
Switch OPEN. Q8 b-e voltage = ?
Switch CLOSED. Q8 b-e voltage = ?
I would then like to look at how you have configured your oscilloscope.
Excellent.
So, what we are now going to do is to test the transformer by injecting a 'pulse' of current into one of the windings and monitoring the output pulse on another winding.
To do this you are going to connect the 100 Ohm resistor in series with the 9 Volt battery (to limit the current flow to a maximum of 9/100 = 90 mA) and use this as a 'stimulus'. You are going to use your oscilloscope to measure any resultant pulse in the second winding.
This test is performed with the power switched OFF to the Amiga CDTV-1000.
Connect your oscilloscope up to T1 pins 1 and 9. Signal to T1 pin 9 and screen to T1 pin 1. Set the oscilloscope for something like 100 mV/division and a slow timebase. Put the Y-level (with no signal) in the middle of the screen. All we are looking for is a 'glitch' appearing on the oscilloscope whenever you connect and disconnect the battery/resistor to the other winding.
Connect the battery/resistor series combination to T1 pins 6 and 8 (with the display NOT connected). It doesn't matter which way around the leads go.
Observe any glitches on the oscilloscope when connecting and disconnecting the battery/resistor.
If you don't see anything at all. Put the oscilloscope on T1 pins 6 and 8 and the battery/resistor on T1 pins 1 and 9 and see what happens when you connect and disconnect the battery/resistor.
Keep your fingers away from touching any wires when you do this - just in case things work! You may get a little electric shock if you touch the parts!!!
If you see some glitches on the scope, then we can look at the primary side next.
If you don't see any glitches, can you post a photograph of your oscilloscope screen please.
