daver2
10k Member
That appears to be pin 7 that has broken off not pin 9?
Can you still see the wire that would have been attached to the pin?
Zero Ohms is just too low (in my opinion) for the winding resistance from pins 2 to 3.
With the transformer out of circuit, can you repeat the same test that we did back in post #92 to see if the primary winding is actually doing what it is supposed to be doing.
