VCF Southwest | Jun 20 - 22 2025, | University of Texas at Dallas |
VCF Southeast | Jun 20 - 22 2025, | Atlanta, GA |
Thanks for the heads up! I've only picked up the typewriter console so far. I'll pick up the rest of the components in November and will keep that drive warning in mind.Hey Stephen, tried emailing you privately but for some reason my email client doesn't like your address. Anyhow, one word of advice, and perhaps it’s already been addressed, but if it’s possible to raise the heads on the magnetic drum before transport, do so.
One word of advice, and perhaps it’s already been addressed, but if it’s possible to raise the heads on the magnetic drum before transport, do so.
I bought an LGP-30 some years ago and had it shipped, but I drove roughly 3000 miles to hand carry the drum (and Flexowriter), to avoid damage. The smartest thing I did once home was to back out the mounting screws securing the many head support bars, before attempting to give the drum a spin to check the bearings (and boy were they dry). After some very careful measurement with brass shim stock, I determined that the drum had in fact swelled by a few thousandths over the years, and the oxide was in direct contact with multiple heads which would have permanently destroyed the drum had I spun it. With all bars raised with washers as spacers, I could then tackle each bar, one at a time, getting the head gap correct as I went.
Hopefully yours won’t have this problem, but there’s an overwhelming urge to just give that drum a spin “just to see". I highly recommend not doing that : ) -C
The G-15 had three timing tracks on the drum. Two were simple clock tracks and were permanently recorded. They were duplicates of each other -- apparently a tube failure in the read circuitry could cause corruption of a track, hence the redundancy. The bad track could be restored in the field by a maintenance technician.The big restoration problem with the G-15 is the drum, which lives near the bottom of the cabinet.
The timing chain for the computer is encoded on that drum. As far as I know, no one has archived
the drum's contents.
The LGP-30 has similar problems, and is a marvel in what they did with so few parts.
Not quite. The G-15 operated bit-sequentially in synchrony with the drum revolution. There were a half-dozen bits from a timing track that marked certain boundaries in instruction words and signaled the necessary logic operations in the processor.Curious what this means - are we talking about the basic control sequencing for the CPU or something of that nature? Interesting design choice if so, but I could see the logic behind it.
The number track data has survived and is available as the first block of http://www.piercefuller.com/collect/bendix/bxtst.pt.
I had some brief correspondence with him about a year ago when I was working on a G-15 emulator. I asked about the tapes. He said he still has them, but some have been in water and will need restoration before they can be read. He's interested in capturing their contents, but said it would probably be a while (years) before he could get to it. He said he also has tapes for the LGP-30 and RPC4000. I didn't ask, but I suspect that he may be amenable to someone coming in and either helping with this, or taking it over.Has anyone been in contact with Paul [Pierce]? Did his G15 and the tape collection go to LCM?
It isn't at CHM. That paper tape collection was irreplacable. It contained the only known copies
of the G15 user's group tapes.
I had just found those resources. That's a big help. Right now the emulator is failing (off by one) to compute a good checksum for the number track. But that's a lot working. The whole I/O system is pretty well exercised by reading in the paper tape to the number track and the first block of code into line 19. I put this project aside eight years ago when I realized just how hard it would be to debug. The original idea was to put the whole G15 into an FPGA... but that was even harder to debug. Transcription of the schematics into it's inherent logic was quite a chore too.An ASCII paper tape image of PPR is available at https://github.com/retro-software/G15-software/tree/main/PPR. This is preceded by the number track. See the README for provenance and a link to some documentation.
If you are working on an emulator, you will probably want to check out BXTSTS.PT on Paul Pierce's site at http://www.piercefuller.com/collect/bendix/. This is a pretty good diagnostic for the processor. That file is a binary tape image, but an ASCII image of it is available as BXTST.pti at https://github.com/retro-software/G15-software/tree/main/Diagnostics. Again, see the README for provenance and documentation.
I'd be really interested in learning more about your gate-level emulator.
I have written an emulator for a basic G-15D system (paper tape and typewriter I/O only) that runs in modern web browsers. It works mostly at the word-time level and attempts to run at the speed of a real G-15. You can run it directly from its hosting site at https://www.phkimpel.us/Bendix-G15/ or you can download the files from the project repo at https://github.com/pkimpel/retro-g15/ and set them up on your own server. See the Getting Started document in the project wiki.
I have a long-time friend who recently mentioned to me that he has an old computer in his garage that he’d like to find a good home for, preferably a museum.
“What type of computer is it?”, I asked.
“A Bendix G-15”, he answers.
“Oh cool”, I answered, having no clue what he was talking about.
I had to look it up and what I found was absolutely amazing.
The Bendix G-15 is a very early (1956) vacuum tube computer based on Alan Turing’s Pilot ACE. It was hailed as the first “personal computer” (meaning it only need one person to operate it) and was one of the very last vacuum tube computers produced. It’s an odd beast, unlike any other computer I know of. It has a 29-bit word length, a whopping 2,160 words of magnetic drum memory, and an almost indecipherable instruction set. All operations are performed 1 bit-at-a-time.
Currently, I'm hitting some issues with the divide logic. The PPR is loading, but I need to code up a Flexowriter emulation to get the user interface up and running.I had just found those resources. That's a big help. Right now the emulator is failing (off by one) to compute a good checksum for the number track. But that's a lot working. The whole I/O system is pretty well exercised by reading in the paper tape to the number track and the first block of code into line 19. I put this project aside eight years ago when I realized just how hard it would be to debug. The original idea was to put the whole G15 into an FPGA... but that was even harder to debug. Transcription of the schematics into it's inherent logic was quite a chore too.
