Ops....this means i have to redo everything from the beginningI would be inclined to 'turn around' your ICs though so that VCC is at the top right and GND is at the bottom left. This is generally how ICs appear on datasheets and in schematics.
These are GATES not IC PACKAGES.on the ruud s' schematic i see:
4 74ls08
2 74ls221
2 74ls123
3!These are GATES not IC PACKAGES.
There is 1 74LS08 IC PACKAGE containing 4 individual GATES.
How many physical ICs can you see on the video board in your photograph?
Ok thanks so much!In case you're still confused: if your circuit needs 4 logic AND gates and a 74LS08 contains 4 AND gates, are you going to buy 4 ICs and just use 1 gate or are you going to use all 4
I might be interested in having one of these boards too. I thought of designing it but it's more fun to watch you doing it... don't give up!
Correct!
It s very difficult job for meThe other thing I notice is that your JP1 header is 2x4 and it should be 1x4. You already had the correct part back in post #37. You just needed to flip the symbol so the connections were to the right hand side rather than to the left hand side.
Ditto for JP2 - it should be a 1x7 header and it looks like 2x7.
