Thanks guys. I'll check it out. I'm trying to think if I ever saw color out of this particular machine but i'm not sure now. I'm pretty sure when I was doing testing I had it on a regular 3 foot composite cable. I then had it hooked up to the video production module and actually did some video titling with it, put it away.. and then it was after when I fired it up I saw it was only coming up black and white on my composite monitor. I recall when I was using the titling system the video was rather unstable and unhappy - so when I only got black and white recently I thought maybe it'd damaged something. RGB is still fine. A couple of days ago I wondered aloud if it was the monitor acting up, so I grabbed a nearby cable and plugged into my 1701... and it was color. But that was a long cable again. I'm going to see if the long cable trick works on the IIe monitor I was originally using.
I recall reading somewhere that Mindset has a key bit or something that, when doing video production, can turn color on and off. But I'd assume it would default back to the original state as soon as power was off.
