TheMatrix
With NOP still the same.
I will try again tomorrow just to be sure.
| VCF SoCal | Feb 14 - 15, 2026, | Hotel Fera, Orange CA |
| VCF East | Apr 17 - 19, 2026, | InfoAge, Wall, NJ |
| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF Montreal | See you in 2027, | RMC Saint Jean, Montreal, Canada |
I will first try V05 then. Where can i find this version?There is still a fault in the DRAM.
It is good enough to pass the 'simple' tests but then fails on the full memory test.
However, some memory is needed to run the full memory test. A chicken and egg situation I am afraid.
PETTESTER V5 will have a more thorough 'simple' memory test...
This is also i nice to haveI made this memory test system which does get around that chicken & egg thing, but it may not be suited to all PET boards, it works well on the dynamic pet with the 4116 DRAM array, basically it deactivates the lower 1k or 2k of DRAM and electronically inserts a good SRAM so the computer can boot to BASIC and then that can be used to help diagnose troubles by examining the remainder of memory either by using PEEKs & POKES or running short prigrams to fill the memory with various bytes. Depending on the exact PET board it may need a different connector. It also eliminates the requirement of all of the DRAM support circuits from the fault equation, but they still run normally, so they can be checked with the scope to see if they are working properly.
www.worldphaco.com/uploads/DRAM%20MEMORY%20TEST%20SYSTEM%20FOR%20THE%20DYNAMIC%20PET%20COMPUTER.pdf
The first one I made was on a hand wired proto pcb. Then I had a few pcb's made. It wasn't a project to sell, but I have a spare unpopulated pcb or two, I could send one over for $20 if you got stuck.
Have you tried the "piggy-back" method (one DRAM at a time)? Not a fool-proof method, but it can yield some results.
Do you mean it performed the DRAM test for 2 hours and increased the PASS counter on a regular basis? <-- Yes!>>> It run correct for like 2 hours.
This would indicate to me that the DRAM is actually OK.
Either your 'fix' was not really the fix - and you still have a bad connection somewhere. Replacing the ROM caused the problem to occur.
Or you have just had another fault occur by powering OFF and back on.
