Ok. So the installation could be in the two ways that I send in the files, right?
Would option 1 and option 2 work the same?
As I mentioned in post #19, the bridge rectifier can prevent reverse polarity accidents, because the apparatus will work regardless of which way you hook up the DC source. This adds a level of safety for all the IC's on the pcb, along with the analog regulator protecting them too.
Just using a single series diode will also prevent a reverse polarity accident, but in that case it will only work when the correct polarity is applied. The only disadvantage is heat generation in the diode/s which is the product of their forward voltage drop and current. Using Schottky power rectifiers can cut those losses nearly in half compared to a standard silicon rectifier because their forward voltage drop is lower.
I'm pretty sure that in at least one case of a PET repair we have seen on the forum, where there were multiple failed IC's in the circuitry fed by one of the 5V regulators, that it was either due to an improvised 5V power supply being inadvertently connected to it in reverse, or an accidental input output short of the 5V regulator with debris on the workbench.
Generally, with original hardware, it is fairly difficult to have something like a reverse polarity accident because the connectors only fit one way. It is when modifications are made, like adding non-standard power supplies that things like over voltage and/or reverse polarity accidents can destroy multiple IC's on a computer mobo, so a lot of caution is required when doing it.
Also, most SMPS's designed for computer use, generally have under and over-voltage protection and over-current protection, with output voltage window monitoring and shutdown, or other systems with SCR crowbars. Generic SMPS's are not often gifted with the extra protective systems which are helpful in protecting pcb's with multiple IC's. In general, when I see projects where original computer supplies, especially analog ones, or any type, are replaced with non-standard supplies, especially ones not designed for specific computer use, it makes me nervous, because of the range of things that can can wrong, not anticipated by the people making the modifications.
On the other hand, analog supplies don't generally have an over-voltage failure mode (it can happen in rare cases with shorted pass transistors), unless say you plugged a 115v unit into a 230V source. Manufacturers knew about this obvious mistake, that is one reason why there is primary fusing on the transformers and the analog regulators which have output voltage clamps, normally will protect the IC's in the event of that accident. In the SOL-20 they also included an SCR crowbar circuit.
One relative advantage of many modern SMPS's is that they are universal voltage input, and that is helpful.
