I took a look at Crystalfontz. Their graphical OLEDs and LCDs max out at 320x240 resolution, so that's no good for printer emulation. But they are easy to interface to; I've used old Nokia displays in the past and they were nice.
Higher resolutions are only available through TFTs, which either use an RGB or MIPI interface. Both types are not cheap and require you to use a controller with hardware support for them, which usually limits you to the higher-end, more expensive variants. Or you use a display with HDMI support and go full SBC, as many projects seem to do now. (After dealing with MIPI camera sensors, I don't want to touch MIPI displays at all.)
Actually, eInk displays would be the perfect technology in this application, but I have never found larger ones. Apart from very few, older high-end devices, there aren't even full page sized eBook readers out there. I don't understand why, these would be great for looking at larger schematics.
