If you want to be future proof you are going about this all the wrong way. Anything obsolete now will be harder to find later on anyway. While I have stacks of working and tested IDE (laptop and desktop) and SCSI drives from 80MB and up I figure most others don't and eventually I will run out or the ones I have will die.
What we realy need is a device that mimicks a HD but in reality is just an ethernet device that connects to any server which runs a special bit of code that creates a virtual HD file for the system we want to use. This would also make it very easy to swap hds for different tasks as needed and also make backup very simple (using the server machine). Most people have ethernet in the house (maybe even have an option for wireless) and hubs/switches and cables are pretty much free for anything pre GB ethernet. None of these old rigs needs over 1MB/sec transfers anyway (ISA bus is the limiting factor) so even 10mb is fine.
Another option would be to just have a commodity RAM based system with a rechargable battery for storage (should last a while) or just connect it to a USB keyring to transfer the HD image over if the battery is dead.
USB and ethernet will be around much longer then the different flash interfaces and ancient IDE/SCSI drives.
