Some steps forward, some steps back.
The bad:
My MSC 32kW card seems to have stopped working suddenly. Bus timeouts.
But I shall rearrange some cards and retest I suppose, with various termination and refresh signals.... I'd tested it with the qbone as bus master (no cpu) the other day and it tested fine, but now it won't respond at all. D:
With 12kW of Heathkit SRAM installed, everything hangs trying to boot, even though all the ram on those cards tested good. Weird. I guess I need to retest them.
The good:
My 2mb cards arrived yesterday. With one of them installed, various OSen seem to boot as they should. Although I cannot use more than 128kW until I wire wrap the backplane to 22 bits.
On that topic:
Unless I am full of poo, according to the documentation BDAL18..21 on the 11/2 CPU expose some troubleshooting signals or somesuch on the backplane. So if I wrap the backplane for 22 bits, I fear that trying to test stuff with the 11/2 in there will cause trouble. This leads me to think that maybe I should just cut the traces on the 11/2 card that connect to the BDAL18.21 pads on the edge connector, and then it will work in a 22 bit backplane without causing hinkiness. Would this be sacreligious? I'd hate to be excommunicated before the project is done, but on the other hand I kind of have a feeling that nobody really cares about the low-end CPUs. I'm happy as long as the modifications are documented and that documentation and all the original hardware stays with the H11 and all goes on to the next guy as a unit someday when I get mauled by a bear or something.
