circa77
One more time, still not a good argument, as the 14411 was also CMOS. Just because HP did it once doesn't make it the right answer for all time.
I don't understand this. At the end of the day (unless you're using those little teeny SMT single gates that Fairchild put out a bunch of years ago - I don't know if anyone else second-sourced them), all 7400 roads lead to the same 14p DIP (or SOIC - whatever). How does "creat[ing your] own packages" in the CAD system affect the final layout - unless the problem you experienced was that it wouldn't allow you to choose which gate to use for which connection?The thing I don't like the most is that it breaks the multi gate parts into individual schematic gates.
When I was doing my 4004 project I had to create my own packages as complete packages and not gates as I wanted to better optimize the physical layout to minimize the size of the finished board.
Well, I don't know about this, the argument doesn't wash in my book.One more time, still not a good argument, as the 14411 was also CMOS. Just because HP did it once doesn't make it the right answer for all time.
Yes, one can put the entire schematic together and then use the back-annotation method but it is clumsy. If the schematic shows the packages used one can visualize the physical layout at the schematic level. Waiting until you are at the layout level is like shouting yourself in the foot, if you know where things were going at an earlier stage. On my projects I've done with wire wrap I've always considered the package layout as part of the schematic, to better position the packages on the board. Why would I do it differently because I can do it different.I don't understand this. At the end of the day (unless you're using those little teeny SMT single gates that Fairchild put out a bunch of years ago - I don't know if anyone else second-sourced them), all 7400 roads lead to the same 14p DIP (or SOIC - whatever). How does "creat[ing your] own packages" in the CAD system affect the final layout - unless the problem you experienced was that it wouldn't allow you to choose which gate to use for which connection?
In Mentor we have a "gate swap" function in layout. If you don't like the way the gates were assigned during packaging, layout lets you click on one gate, click on another gate, click "swap gates", and all the connections are (correctly) exchanged between the two. Then, when you do a back-annotate, that gate swap is propagated back to schematic capture ("Design Architect" in Mentor-speak) and the drawing updated to reflect the reassignment. Those swaps, of course, don't have to be within the same package - you can have two 7400s on opposite ends of the board and swap gates between them. Similarly, you can swap pins within a gate - if your layout will benefit from swapping pins 1 and 2 of that 7400, you can do that too, and it'll make its way back to the schematic as well.
As for the short-guide problem, I've never heard of any package that would bow a guide wire for the benefit of readability - maybe it's out there, but I've never seen it. When I'm getting close to the end of routing a board and want to see if there are any such that I've missed, there's a number on the screen that tells me how many unrouted nets (i.e. guide wires) are still there. Then, if I can't immediately spot it, I just turn off all the other layers - and there it is.
Hugo, you need to actually read the data sheet. Those two inputs select one of four baud rate sets, not one of four baud rates.The reason is that the MC14411 chip you cited, while saving a few IC's, only has a 2 bit input for Baud rate control. Meaning it can only provide four possible baud rate settings.
Okay, I get it. It's a bit of an odd approach, but if it works for you, sure. Personally, I wouldn't bother with creating the already-packaged schematic symbols to be able to do it that way; generally speaking, schematic capture is for getting the logical/electrical function of the circuit right in a symbolic sense, exclusive of physical considerations. To me it makes ample sense to have in my head a rough intuitive idea of what the placement is likely to be, and once I'm packaged and in layout I'll usually let it do an autoplace and then stare at the resulting ratsnest for a while and push the components around toward their final locations. Then my last lines of defense are the gate and pin swaps I mentioned previously. In the case of my system there's nothing at all clumsy about the backannotation process - it's extremely tightly integrated and I don't think I'd have any trouble at all achieving the same result as yours.Yes, one can put the entire schematic together and then use the back-annotation method but it is clumsy. If the schematic shows the packages used one can visualize the physical layout at the schematic level. Waiting until you are at the layout level is like shouting yourself in the foot, if you know where things were going at an earlier stage. On my projects I've done with wire wrap I've always considered the package layout as part of the schematic, to better position the packages on the board.
That's a pretty broad claim. I'm not going to dispute it, but I'm unlikely to accept it without citations.Many LSI circuits were produced, purporting to replace arrays of logic IC's from the 70's era, claiming equal or better performance. But fell short.
Seems to me like the original design is just begging to be implemented in an FPGA - or maybe just a CPLD, 'cause 65 SSI/MSI packages ain't nuthin'.... Yeah, there we go. A guy at Columbia did just that about ten years ago.The finest example I know of this was Atari's Arcade Pong, with 65 IC's and possible ball motion vector states of 42 (Just a coincidence with the answer to life the Universe and everything on Hitchhiker's Guide to the Galaxy). They squashed it all into one LSI IC for the home Pong consoles. The number of shortcuts reduced the ball vectors and the game was nowhere as good.
It has been done for the KIM-1. Look at http://retro.hansotten.nl/6502-sbc/kim-1-manuals-and-software/kim-1-6530-replacement/ All 6532s are functionally equal btw, no mask programming. The 6530s have mask programming. The logic in the replacement circuits take care to map the 6532 to the 6530-002 and -003 specific memory layout.I wonder if this would physically fit in a KIM-1 and work with the right ROM contents and the right 6532 to replace the 6530 ?
6530 RRIOT Replacement kit for CBM IEEE Drives
If you have diagnosed your CBM IEEE drive and discovered the 6530 is faulty, you can use this to replace it. I also carry other parts used in these drives including 2114 SRAM, and 6502 and 6504 CPUs. This does not come assembled . You must solder it together. The photos only show the completed...monotech.fwscart.com
(I know these are good for the drives, I bought one in the past and they are good value for money too)
I think this is the same basic design as the adapter board made to replace the 6530 in the SFD-1001 and some other Commodore drives.
But, in all cases, as far as I know you cannot use just any 6532, because of the mask programming of the chip select pins. So only a certain number of 6532's will be compatible for the specific application.
Ok, thanks I'll have to check the data sheet. And then it totally out-does the one made from CMOS IC's. I guess there must have been some factor of economy or availability of the Motorola thip chat caused the T-W people not to use it at the time in the late '70's.Hugo, you need to actually read the data sheet. Those two inputs select one of four baud rate sets, not one of four baud rates.
Each of those sets gives you 16 simultaneous outputs (including the 1.8432MHz clock), which you can then choose from with a DIP switch.
I liked the look of the Monotech adapter because it is very compact.It has been done for the KIM-1. Look at http://retro.hansotten.nl/6502-sbc/kim-1-manuals-and-software/kim-1-6530-replacement/ All 6532s are functionally equal btw, no mask programming. The 6530s have mask programming. The logic in the replacement circuits take care to map the 6532 to the 6530-002 and -003 specific memory layout.
Shouldn't have been - I knew the part because it's what was used in my first system, the SWTPC 6800, so they'd been around for years and were common as muck. And as I said, once you factor in its replacing multiple parts, reducing real estate, and assembly time and cost, there shouldn't have been much reason not to go with it.Ok, thanks I'll have to check the data sheet. And then it totally out-does the one made from CMOS IC's. I guess there must have been some factor of economy or availability of the Motorola thip chat caused the T-W people not to use it at the time in the late '70's.
I can't be the only person who's really struggling with the very existence of all these goddamn counterfeits. I know who does that, but who does that? It doesn't seem much in keeping with either Confucian or Christian principles, but I guess "sell roundeyes' garbage back to him" is the order of the day.It is good to know that any 6532 will work. I did try to get some, they turned out to be fakes, that did nothing and just generated heat, clearly they were some other IC.
One thing that is really messing with my head lately on fakes is:I can't be the only person who's really struggling with the very existence of all these goddamn counterfeits. I know who does that, but who does that? It doesn't seem much in keeping with either Confucian or Christian principles, but I guess "sell roundeyes' garbage back to him" is the order of the day.
I don't know if that would help me, because each day it kept working I'd be thinking, hmmm......I wonder if it will fail tomorrow and be back to square 1, worrying about its integrity.I feel you, but what you did with it probably wouldn't be my approach.
If it works but I'm "concerned" about it, there's nothing better than to press it into service, and if it fails, it fails. The only things that are going to unwrap that mystery are volts and time; it'll be suspect until operation proves it otherwise... or kills it. Either way, you'll know.
On the other hand, the last thing I want on the shelf is an unknown part, or one I'm nervous about, because I'm probably going to reach for it when I most need something that works.
Looks like a Rev D, quite common. Sticker on the brand name, which is Commodore C-MOS. f the 003 is in a socket, maybe it it has replaced a damaged 003. 6530-002 and -003 were for sale in those days.I found a picture of it here. It was I think an 'unbranded' version. And it looks like they modified it - the -003 ROM is in a socket and then they have an EPROM attached to the user port. I remember it had instructions for firing up some kind of cooling system or something like that. Ugh why did I sell that for a lousy $300.
I see no reason it couldn't be used. You have to use the correct EPROM or what ever and preprogram it.It has been done for the KIM-1. Look at http://retro.hansotten.nl/6502-sbc/kim-1-manuals-and-software/kim-1-6530-replacement/ All 6532s are functionally equal btw, no mask programming. The 6530s have mask programming. The logic in the replacement circuits take care to map the 6532 to the 6530-002 and -003 specific memory layout.
