intabits
I wanted, but could not find a cleanly formatted list of the PDP-8 Omnibus signals.
So I've created the list below from Appendix B of the "PDP-8/e/f/m MAINTENANCE MANUAL VOLUME 1"
Please let me know if:
- Such a list already exists
- This list is of any use at all
- There is a mistake in my list
- (almost certainly) References to M830, M835 & M836 should be M8300, M8350 & M8360?
- You know of any (other) errors in the appendix data
- Any other information should be incorporated in this list (and where to get it)
eg: Type/Class of signal (power, bus, ctrl, misc, etc)
- Other formats for this list are of any value? (eg: CSV)
Notes:
- I'm not very familiar with the signal names, some of the those found in the appendix may not be the definitive ones
eg: those given for C1L, C1V seem weird
- This list is created by some manual editing of a source list, which is read by a program to produce the output below.
So simple formatting changes are easy to make.
- OCR errors are possible, but I think I've caught them all
Some changes were made to the values found in the appendix:-
- '-' replaces spaces in signal names
- P.S. replaced with PSU
Notes:
Pin Signal Source Destination
A1A TP Not bussed
A1B TP Not bussed
A1C SPGND PSU ALL
A1D MA0-L M8360,M8300 KC8-EA,M8330,M8300,G227
A1E MA1-L M8360,M8300 KC8-EA,M8330,M8300,G227
A1F GND PSU ALL
A1H MA2-L M8360,M8300 KC8-EA,M8330,M8300,G227
A1J MA3-L M8360,M8300 KC8-EA,M8330,M8300,G227
A1K MD0-L M8300,G104 KC8-EA,M8330,M8310,M8300,G104,M8350
A1L MD1-L M8300,G104 KC8-EA,M8330,M8310,M8300,G104,M8350
A1M MD2-L M8300,G104 KC8-EA,M8330,M8310,M8300,G104,M8350
A1N GND PSU ALL
A1P MD3-L G104,M8300 KC8-EA,M8330,M8310,M8300,G104,M8650,M835
A1R DATAO-L KC8-EA,M8350,M8300,M8360 KC8-EA,M8330,M8300,M8350,M8360
A1S DATA1-L KC8-EA,M8350,M8300,M8360 KC8-EA,M8300,M8350,M8360
A1T GND PSU ALL
A1U DATA2-L KC8-EA,M8350,M8300,M8360 KC8-EA,M8330,M8300,M8350,M8360
A1V DATA3-L KC8-EA,M8350,M8300,M8360 KC8-EA,M8300,M8350,M8360
A2A +5 PSU ALL
A2B -15 PSU ALL
A2C GND PSU ALL
A2D EMAO-L M8360 KC8-EA,G104
A2E EMA1-L M8360 KC8-EA,G104
A2F GND PSU ALL
A2H EMA2-L M8360 KC8-EA,G104
A2J MEM-START-L KC8-EA M8330
A2K MD-DIR-L M8330,KC8-EA,M8360 KC8-EA,M8300,G104
A2L SOURCE M8330 G227
A2M STROBE M8330 G104
A2N GND PSU ALL
A2P INHIBIT M8330 G104
A2R RETURN M8330 G104,G227
A2S WRITE-L M8330 G104,G227
A2T GND PSU ALL
A2U ROM-ADDR-L M880 M8310,G104,M880
A2V LINK-L M8310 M8330
B1A TP Not bussed
B1B TP Not bussed
B1C GND PSU ALL
B1D MA4-L M8360,M8300 KC8-EA,M8330,M8300,G227
B1E MA5-L M8360,M8300 KC8-EA,M8330,M8300,G227
B1F GND PSU ALL
B1H MA6-L M8360 KC8-EA,M8330,M8300,G227,M8300
B1J MA7L M8360 KC8-EA,M8330,M8300,G227,M8300
B1K MD4-L G104,M8300 KC8-EA,M8330,M8310,M830,G104,M8650,M8350
B1L MD5-L G104,M8300 KC8-EA,M8330,M8310,M830,G104,M8650,M8350
B1M MD6-L G104,M8300 KC8-EA,M8330,M8310,M8300,G104,M8650,M8350
B1N GND PSU ALL
B1P MD7-L G104,M8300 KC8-EA,M8330,M8310,M8300,G104,M8650,M8350
B1R DATA4-L M8360,KC8-EA,M8650,M8300,M8350 KC8-EA,M8300,M8650,M8350
B1S DATA5-L M8360,KC8-EA,M8650,M8300,M8350 KC8-EA,M8300,M8650,M8350
B1T GND PSU ALL
B1U DATA6-L M8360,KC8-EA,M8650,M8300,M8350 KC8-EA,M8300,M8650,M8350
B1V DATA7-L M8360,KC8-EA,M8650,M8300,M8350 KC8-EA,M8300,M8650,M8350
B2A +5 PSU ALL
B2B -15 PSU ALL
B2C GND PSU ALL
B2D INTSTROBE M8330 M8330,M8360
B2E BRK-IN-PROG-L M8360 KC8-EA
B2F GND PSU ALL
B2H MA-MS-LOAD-CONT-L M8360 M8310
B2J OVERFLOW-L M8310 M8360
B2K BRK-DATA-CONT-L M8360,KC8-EA KC8-EA,M8310
B2L BREAK-CYCLE-L M8360 KC8-EA
B2M LD-ADD-ENABLE-L KC8-EA KC8-EA,M8310
B2N GND PSU ALL
B2P INT-IN-PROG-H M8330 M8310,M8330
B2R RES1 Reserved for DEC use on1y
B2S RES2 Reserved for DEC use on1y
B2T GND PSU ALL
B2U RUN-L M8330 KCS-EA,M8330,M8350
B2V POWER-OK PSU M8330,G104
C1A TP Not bussed
C1B TP Not bussed
C1C GND PSU ALL
C1D I/O-PAUSE-L M8330 M8330,M8310,M8650,M8350
C1E CO-L M8650,M8350,M8330 M8310
C1F GND PSU ALL
C1H C1-L M8650,M8350,M8330 M8310
C1J C2-L M8350 M8310
C1K BUS-STROBE M8330,M8350 M8310,M8330
C1L INTER.-I/O-L M8330 M8650,M8350
C1M NOT-LAST-TRANSFER-L M8350 M8330
C1N GND PSU ALL
C1P INT-RQST-L M8650 M8330,M8350
C1R INITIALIZE KC8-EA,M8330 KC8-EA,M8330,M8310,M8300,M8650,M8350,M836
C1S SKIP-L M8650 M8330,M8310
C1T GND PSU ALL
C1U CPMA-DISABLE-L M836 M8300
C1V MS-IR-DISABLE-L KC8-EA M8330,M8310,M8360
C2A +5 PSU ALL
C2B -15 PSU ALL
C2C GND PSU ALL
C2D TP1-L M8330 M8310,M8330,M8350,M8360
C2E TP2-L M8330 M8310,M8330,M8350,M8360
C2F GND PSU ALL
C2H TP3 M8330 M8310,M8330,M8650,M8350
C2J TP4 M8330 KC8-EA,M8310,M836
C2K TS1-L M8330 KC8-EA,M8330,M8310,M8350,M8360
C2L TS2-L M8330 M8310,M8360
C2M TS3-L M8330 KC8-EA,M8310,M8350
C2N GND PSU ALL
C2P TS4-L M8330 KC8-EA,M8310,M8360
C2R LINK-DATA-L M8330 M8310
C2S LINK-LOAD-L M8330 M8310
C2T GND PSU ALL
C2U IND1-L KC8-EA M8330,M8310
C2V IND2-L KC8-EA M8330,M8310
D1A TP Not bussed
D1B TP Not bussed
D1C GND PSU ALL
D1D MA8-L M8360,M8300 KC8-EA,M8330,M8300,G227
D1E MA9-L M8360,M8300 KC8-EA,M8300,G227
D1F GND PSU ALL
D1H MA1O-L M8360,M8300 KC8-EA,M8300,G227
D1J MA11-L M8360,M8300 KC8-EA,M8300,G227
D1K MD8-L G104,M8300 KC8-EA,M8330,M8310,M8300,G104,M8650,M8350
D1L MD9-L G104,M8300 KC8-EA,M8330,M8310,M8300,G104,M8650,M8350
D1M MD10-L G104,M8300 KC8-EA,M8330,M8310,M8300,G104,M8650,M8350
D1N GND PSU ALL
D1P MD11-L G104,M8300 KC8-EA,M8330,M8310,M8300,G104,M8650,M8350
D1R DATA8-L M8360,KC8-EA,M8650,M8300,M8350 KC8-EA,M8300,M8650,M8350
D1S DATA9-L M8360,KC8-EA,M8650,M8300,M8350 KC8-EA,M8300,M8650,M8350
D1T GND PSU ALL
D1U DATA10-L M8360,KC8-EA,M8650,M8300,M8350 KC8-EA,M8300,M8650,M8350
D1V DATA1-1-L M8360,KC8-EA,M8650,M8300,M8350 KC8-EA,M8300,M8650,M8350
D2A +15 PSU ALL
D2B -15 PSU ALL
D2C GND PSU ALL
D2D IRO-L M8310 KC8-EA,M8330,M8310
D2E IR1-L M8310 KC8-EA,M8330,M8310
D2F GND PSU ALL
D2H IR2-L M8310 KC8-EA,M8330,M8310
D2J F-L M8310 KC8-EA,M8330,M8310
D2K D-L M8310 KC8-EA,M8330,M8310
D2L E-L M8310 KC8-EA,M8330,M8310
D2M USER-MODE USER KC8-EA,M8330
D2N GND PSU ALL
D2P F-SET-L M8310 KC8-EA,M8330,M8310
D2R PULSE-LA-ADDR-H KC8-EA M8310
D2S STOP-L M8330,KC8-EA M8330
D2T GND PSU ALL
D2U KEY-CONT-L KC8-EA M8330,M8310
D2V SWITCH-L KC8-EA KC8-EA
