MattisLind
What do you mean by "Boot Solo"?Hi All;
On a side not I tried to Boot Solo and got an I/O Error.. I am going to try and figure out what Disks and tape are available, and see if it will work on something.. There is both a Tape and Disk file.. Once I know what Tape machines would most likely work, I will try that route..
It doesn't look like the Tape file is Bootable..
If not, I need to find out How to Load the PAL assembler and feed it the various Test files..
THANK YOU Marty
The images I provided in links should be bootable on a 11/45. Just make sure that your attach works without creating a new file. It is easier to work with disks rather than tapes unless you ant to do a new install.
You can deposit into memory using "d" command. Useful to deposit boot-code if that is not already present in SimH. I am not sure about SimH but E11 (Ersatz-11) includes an assembler so that you can enter assembly code directly and test and run it.
