m_thompson
We tried to control the TU55s through the controller. If we command the drive to move, it moves about 1mm, stops, and shows an END error. It thinks that it went into the end zone so it stopped the tape.
After several hours of debugging we found that the G882 modules are oscillating when the tape is stopped. This is normal. The G882 module for the Mark track sends the decoded "data" to the Window Register, and after about 150ms the TP1 pulses show up. This starts clocking the "data" into the Window Register and eventually the code for the End Zone shows up in the Window Register. This is just random data and the TP1 pulses shouldn't be present.
It looks like the signals from the Write Mark Track switch are not pulled down enough, so in the active state the signal is at -1.8V. It needs to be below -2.0V to be active, and this eventually lets the TP1 pulses into the Window Register before the Up To Speed signal goes active.
Maybe I can get some time today to debug this, and compare the signals to the ones on the TC01 on the PDP-8/I.
