Ok ok now i see that signal in post 221 is more stable and definited!Can you see what the difference between the two videos posted in #208 (bad) and #221 (good)?
I have always LOW signal on CPU pin 7Ok,
Can you remove the NOP generator and make sure the Kernal and PETTESTER ROMs are fitted to UD9 and UD8 respectively.
Leave UE9 and UE10 out of the sockets.
Don't get desparate, but the screen will probably contain cr*p. This is expected behaviour because buffers UE9 and UE10 are not fitted!
What we want to check is pulsing activity on CPU pin 7 and (if this is the case) what pulsing activity is on the pins of UD2.
We are going to check if we can get the PETTESTER to work now, but we won't be able to see anything on the screen! However, if we fit the missing buffers, then the PETTESTER ROM may not work again until we find the fault!
Maybe bad socket roms?Somehow, then, either you have missed something or one (or both) EPROMs are not working correctly in the PET.
I seem to have run the test correctly...maybe there is some logic broken?That is why you did all of the continuity testing that you did...
Now, if you didn't do it properly - this comes under the heading of you missed something...
The point is that we have removed all of the logic from the data bus other than the two (2) ROMs and the CPU... The only other logic device that is present is the 74154 address decoder...I seem to have run the test correctly...maybe there is some logic broken?
So now what can i do?The point is that we have removed all of the logic from the data bus other than the two (2) ROMs and the CPU... The only other logic device that is present is the 74154 address decoder...
That is why I went to the trouble of asking you to remove the VIA, PIAs and the E9 and E10 buffers.
yes these roms are in socket and i already used contact cleaner in socketDesperado,
Are both D8 and D9 on sockets? Sometimes when measuring continuity, pressing hard with probe will give positive result, but there is still intermittent when pressure removed. At least spray some contact cleaner into the sockets.
We are running out of options.
yes but i burned another eprom but doesn't works againIs the Kernal ROM the one that came with the machine?
i have a good reset signal!Also worth double-checking CPU pin 40 to make sure that the CPU is being RESET on power-up or reset (if you still have the pushbutton).
So... Cpu pin 9 to UD9 pin8 for example?The first thing is to repeat the continuity tests from the ROMs back to the data bus of the 6502 CPU
