Dwight Elvey
Dwight, thank you so much for your reply. most of this will require some research or advice on how to achieve these measurement with the scope. i will study it.
First thing to look at is the ripple frequency. If it is 60Hz, you have one bad diode. For ESR, you can look at the shape of the signal after the peak. There will be a curve on the up side and it will go over the peak. If after the peak, if follows a curved path before separating into a straighter discharge line, you'd know that it had poor ESR. If the voltage came up to about 11 or 12 volts and dropped to less than 6 volts between peaks, it would either mean the capacitance was really low ( dry inside ). If the voltage never makes it to 11 or so volts it might mean the load was too heavy.
Dwight
