modem7
10k Member
Regarding eBay item 390024973091 - pre-production IBM 5170 motherboard at $850
* I'm very sure the "AMI" written on the ROMS is an abrieviation of American Megatrends Inc.
* In the 80s, when the company I worked for received boards (of any type) from manufacturers, that contained ROMs with handwritten labels, the handwriting on the labels was neat ('image is everything'). Even serial numbers done by marker pen were done neatly. I certainly would have expected that on a board that IBM knew may be photographed, IBM would have ensured that the handwriting was neat (and the labels themselves cut better).
* The patchwork of yellow wiring is the same as on two 5170 type 1 motherboards that I have access to.
* The two DIL chips dated '82 are similarly dated on two 5170 type 1 motherboards that I have access to.
* I wouldn't have thought that IBM would put a barcode label on a pre-production board, but I concede that they may have done so for tracking purposes.
Weighing that up, I think the board is simply an early type 1 board where an earlier owner has replaced the original IBM ROMs with AMI ones.
