i don't remember what they are, but anyway you can't go wrong with that.Just to confirm the tantalums I need to replace are 10uF, 25 volt?
I intend to replace all of them except for the two large 680uf caps as well as the four located on the two riser boards. I am having my cap guy put kit together. He mentioned it's getting more difficult to get parts so hopefully he can supply all of them. I know he has the 220uf caps in stock. I'm also going to purchase a second set to recap the working power supply.i don't remember what they are, but anyway you can't go wrong with that.
for the PSU, replace also the 2 2200µ. they are of the same series than the 220, and were dead on mine.
as you probably understand, thoses 220 and 2200 are the output capacitors, change them. maybe the 2200 are still good for now, but they'll fail for sure.
they are low esr.
you can replace them with modern very low or simply low esr without any issue.
as NeXT explained, some older PSU design don't like very low esr, specially for the regulation feedback, but no issue with this one.
I'm not sure. If the capacitors don't resolve the issue I'll need to find outcan you test ps2 psus without a load?
You can try the automotive lightbulb method to put an amp or two on the +5 and +12 and that's usually enough to stabilize the rails.I'm not sure. If the capacitors don't resolve the issue I'll need to find out
This is great information. I am hoping, given the symptoms and the ESR meter testing, that the problem is limited to the bad capacitors. In fact I might even know today as they're supposed to be delivered this afternoon.8550 / 8570 / 756x - Power Supply
www.ardent-tool.com
Since I am not a power supply kind of guy what is an appropriate load to put on a power supply for testing?You can try the automotive lightbulb method to put an amp or two on the +5 and +12 and that's usually enough to stabilize the rails.
But it needs to be expanded further - along with the other PS/2 PSUs.This is great information. I am hoping, given the symptoms and the ESR meter testing, that the problem is limited to the bad capacitors. In fact I might even know today as they're supposed to be delivered this afternoon.
The IBM passive bay and card adapter or from a SYSGEN "Bridge" replacement riser? A Reference Diskette will only run from the A: drive. It looks great!One benefit this system has is the external drive cable. It looks to be a straight pass through so I can probably use an external drive to perform the system configuration (though the internal drive works fine).
How do I tell the difference? It appears it could plug into either connector (though it was / is currently installed in the B: drive connector). I'll take a look tomorrow as I'd like to get the case cleaned. $50 for the system and $9.00 worth of capacitors and it's all good.The IBM passive bay and card adapter or from a SYSGEN "Bridge" replacement riser? A Reference Diskette will only run from the A: drive. It looks great!
At the bottom of this page, it shows the passive (4869-001) adapters: https://www.ardent-tool.com/floppy/5_25_Floppy_Adapter.htmlHow do I tell the difference? It appears it could plug into either connector (though it was / is currently installed in the B: drive connector). I'll take a look tomorrow as I'd like to get the case cleaned. $50 for the system and $9.00 worth of capacitors and it's all good.
What to do about the broken SIMM slot. Can I skip it and install memory in the third slot (the center one is broken)? I doubt I'll need a lot of RAM but I've got a stick sitting on top, waiting to be used (though I think it's only 256KB)
a bit late, but you don't need to on this one.Since I am not a power supply kind of guy what is an appropriate load to put on a power supply for testing?
What I have is a simple cable where one end plugs into the floppy connector and the other is a female connector which mounts to the back of the system. It appears that a Type 4869 External Floppy drive would plug into the female connector on the rear of the system.At the bottom of this page, it shows the passive (4869-001) adapters: https://www.ardent-tool.com/floppy/5_25_Floppy_Adapter.html
Very similar to a couple that I have around - after-market, but not the SYSGEN "Bridge" adapter by what I can see. There were a few manufacturers putting out unbranded cable and drive assemblies for the PS/2s - One I received even had the power plug mixed up!What I have is a simple cable where one end plugs into the floppy connector and the other is a female connector which mounts to the back of the system. It appears that a Type 4869 External Floppy drive would plug into the female connector on the rear of the system.
