Chuck(G)
25k Member
I was a bit let down that the Syquest Sparq drive was offered only in parallel port version. I've got one and i think I've had it out of the container only once.
From what I recall, the Sparq drive was basically introduced to compete with the Jaz which was doing much better than the Syjet 1.5gb due to errors on the cartridges. I could be completely off base here as my memory has faded quite a bit about those years, but living through them was quite exciting--Jaz, zip, syquest, mo, floptical, oh my!
Ah yes! All those others too!Syjet was a follow on to the 270MB design. Originally about 650 MB which seemed reliable in prototypes; doubled to 1.3 GB when Iomega introduced Jaz; increased to 1.5 GB just before release and didn't work. Sparq was to be the ultra cost reduced drive that would have Zip drive appeal. Then there was Quest to get DVD equivalent capacity on a disk. With additional competitors like Avatar Shark and Castlewood Orb and the couple of roughly 2" designs, there must have been close to 20 different systems using removable disks between 1995 and 2000. Exciting unless data gets stored in one of the failure prone models.
Neat! Any driver needed for this?Don't forget the MO drives, such as the PMC Apex. I believe that one could boot from that as well.
You know what--that drive we have is a Pinnacle Micro. I remember because the first one just stopped working for no reason one day and was replaced under warranty.The PM stuff (and probably the Maxoptix) was plain old SCSI, so you could set your controller to boot from it, I seem to remember. They behave like regular hard drives, although PM did offer drivers.
Right after the Apex, Pinnacle circled the drain. Those drives were horrible--they'd go out for seemingly no reason at all. PM was snowed under with warranty returns and were giving numbers like 6 weeks to 3 months before you'd receive a swapped drive (i.e. not you own, but someone else's repaired drive).
The 4.6gb one we have is actually a 2.3gb per side drive and you have to flip the cartridge over. Were these compatible with your 2.6gb drives?I have a few 1.3GB MO drives and a couple 2.6GB ones (ALL SCSI) but never bothered with the 4.xGB ones because they were junk and media is hard to find.
CDR and eventually DVDR killed removable drives just because anybody you wanted to send data to had an optical drive that could read it.
A Parallel port Sparq drive must have been slow. I liked Iomega Jazz drives since they were SCSI.
Collecting removable drives is fun.
Ah yes, the sector sizing. I believe our drive was using 2048 sectors, so it might be one of those formats that was one step away from the WORM drives.IIRC, the small differences in capacity like 2.3 GB versus 2.6 GB were the result of different sector sizes. 2.3 GB used 512 bytes per sector while 2.6 GB used 1024 bytes per sector. Plus there were any number of proprietary capacities.
Some drives supported multiple sector sizes. Most drives had the ability to read/write half capacity discs and read only for quarter capacity; some stretched read only support all the way back to 640MB. The proprietary capacities were generally only supported by the drive that made it and the replacement for it at the next higher capacity. Rather obviated the longevity of WORM discs if it becomes impossible to find a drive that reads those discs.
Parallel port drives were slow; filling a 1 GB Sparq disk took basically the lunch hour. On the other hand, the parallel port drive was a lot easier to attach to a new system.
Just think of the record on the Voyager spacecraft--in another 40 years or so, even the civilization that created it won't be able to listen to it. Audio and video cassettes have almost already gone this route.
And I think you bring up a good point on why removable storage (and even tapes drives for that matter) never made it as a long term archive medium--the inability to play back the media.
..... I have trouble finding stuff on the net written 5 years ago....
Look at the date on that tape. Know any other medium that lasts 50 years and isn't paper?
Samir claims that "tape never made it as a long term archive medium".
....That tape was already 10 years old when Voyager 1 was launched...
