SIP bussed resistor array with common pin centered
maxtherabbit
VA, USA
I have a Mitsubishi floppy drive which used a SIP terminator that is a bussed resistor network, but the common is the center pin. All modern bussed resistor arrays seem to have the common as pin 1. Is there a different name for this type of configuration or are these just no longer made that way?
I've never seen one with a common pin in the center for a bussed resistor network, but I've only been using them for 10-15 years.
I thought about doing that, but I already have an array with the requisite number of resistors. I think I will just install it halfway and run some ribbon wire to the other side
