Hugo Holden
Not to deviate too much from the Retrobrite controversy, but the paint method I suggested shades the plastic from further sunlight damage, helping to preserve it and in addition, the opportunity can be taken to repair chips and cracks and damaged plastic areas prior to the coat giving a much better cosmetic appearance and in addition to this, because of all the shades available with the Dupli-Color, you can have the plastic any shade of white to off white, or practically any other color you like.
My main goals are: 1) preservation of as much of the original plastic material as possible, perhaps extending its life and 2) having an excellent cosmetic appearance.
I just cannot buy into the notion that photon based bleaching or chemical bleaching of the surface plastic meets the "preservation" directive, even if the optical appearance is improved (it is just my personal view).
On the other hand all the rules are different for metals, and rusted metal surfaces benefit significantly for serious electro-chemical treatments involved removing the rust & corrosion prior to re-electroplating them. I specialize in the restoration of vintage TV sets, this article shows before & after chassis photos:
https://www.worldphaco.com/uploads/HMV__904_ARTICLE.pdf
