VECTREX WITH DESPERATION
I have this revision:
That is more helpful.
The -13V is derived from a lower AC voltage obtained from the transformer secondary winding - and then doubled via a diode/capacitor network.
At this point I am not concerned with why you don't have a -13V supply, but why is the AC input supply from the transformer to the voltage doubler not working as expected?
I will post a snipet of the schematic tomorrow and we will take it from there.
Can you see the mains transformer?
There should be one white wire and two red wires coming out of the transformer secondary windings.
The two red wires should go to (and from) a switch. Then via a torroid (ring) ferrite core, and then the red and white wires should be attached to the power board.
Can you follow these wires?
Yes i see these wires !
Now im going to sleep Dave, can we continue tomorrow?
Thanks so much and good night sir!
The transformer windings are used to produce the + and - 5V rails - and these appeared good...
My 'plan' would be for you to measure the AC voltage between the WHITE wire and the two RED wires (2 measurements) and then between the two RED wires. If you could measure these voltages with your multimeter probes both way round and where the wires attach to the power PCB.
WHITE and RED1 - probes BLACK=WHITE and RED=RED1.
WHITE and RED1 - probes BLACK=RED1 and RED=WHITE.
WHITE and RED2 - probes BLACK=WHITE and RED=RED2.
WHITE and RED2 - probes BLACK=RED2 and RED=WHITE.
RED1 and RED2 - probes BLACK=RED1 and RED=RED2.
RED1 and RED2 - probes BLACK=RED2 and RED=RED1.
If this makes sense?
Make sure you mark the two RED wires in some way to differentiate them from each other :).
Ok thanks but must i measure these voltage directly on power board?
You can measure them at either end of the piece of wire... It shouldn't make much difference (unless we have a broken wire)...
Are these the wires?
They look right (if they come from the transformer via the switch).
The white lead should be marked EP105 on the PCB and the two (2) red leads should be marked EP104 and EP106 on the PCB.
10,2 VAC
10,2 VAC
0,27 VAC
0,27 VAC
10,2 VAC
10,1 VAC
Not just yet...
I find an inconsistency in the WHITE and RED2 readings...
Question: Is the RED2 wire connected to the pad marked EP104 or EP106?
I think I can guess - but I want you to confirm...
Not just yet...
EP106 :(
