I'd agree it isn't too easy to get the board into the VESA slot, but I keep at it until I know it's secure now. The one time I thought I had it in and tried it it gave the video error beep code as it did when I had it completely removed, so I went back and got it in correctly and then it didn't beep at all like usual.
So as far as the keyboard goes, should I buy a PS/2 to 5-pin din adapter so I can hook my old PS/2 keyboard to the machine? Was hoping I had one I forgot about but apparently I don't. I'd rather not have to buy a 5-pin din keyboard if the adapter option would work also.
Also just as far as information-wise, you said it just plugs into a VLB slot. I figured just the short brown slot was considered a VLB slot while the longer black ones were ISA. The video card plugs into both adjacent to one another, so you're saying when those two are combined that's what is known as a VESA local bus?
Lastly, I only got the 2 beep code when I found a jumper had fallen off the video card at some point during installation and I powered the PC on. I don't know if that's what caused it but I haven't gotten it again since I put it back on.
