What experience can anyone share in building a case for your computer
bifo86
Virginia, USA
This one is open to the S-100 people. I'm slowly building a retrobrew MSX2, along with a zx spectrum clone board. i think this might be a good case for an 8-bit computer where you have to build a keyboard, but i don't know how to cut metal.
it seems like it will fit the keyboard i built for the MSX2 clone, but it's far too big for the spectrum clone. What have you used for a case, either replacement or new?
The Hammond cases are pretty nice (and not cheap) that case is designed for a keyboard. So its a good fit.
Assuming the dimensions work for your keyboard. Its heavy 12 ga. aluminum It will take serious tools to make the cutout.
Step one: you need an accurate drawing of the cutout you need.
Step two: look for a machine shop in your area and see if they will cut it for you. (may cost $$)
Or... look for a vocational school with a metal working course. suck up to the instructor.
Or sign up for a course. You already have a project.
Over the years I've done lots of custom cases for my projects. Mostly rack mount cases.
You get to hide most of the mistakes that way. I'd hate to screw up a nice case like that.
joe
For terminal-type cases with keyboards, I used Bud enclosures. Not cheap, again, but well-constructed. Cite
Tools are a necessity if you don't want the result to look like a complete hash. At the lowest end, a good metal nibbler is a must; slow-going, but you can produce very clean results. If you can make a wood template of what you need first, a router with a guide and a metal-cutting bit goes much faster. Don't try to do it freehand, however. You'll make a mess. There are also industrial metal-cutting tools that can be accurate to a thou, easily, such as WEDM.
Though not S100, my Mark 8 is built into a home made cabinit. You can see some picture here:
http://i8008.net/MARK8/
I used 1/4 aluminum plate I had laying around. Nothing needed to be bent, I just drilled, taped, and screwed everything together.
For my current "daily driver" retrocomputer centered around a bare Tandy 1000 HX motherboard I built a crude case out of wood that was mostly salvaged from the linen drawer of an old crib. The current end result is heavily inspired by but considerably less finished than this:
Which is no doubt not the angle you're going for.
A thing that's moderately popular these days for one-off custom cases is making a case out of plexiglass bent to shape with a heat gun. For a simple single-board computer that might work well and be a little cheaper than a manufactured case, but making it look "nice" will require careful workmanship.
If you are building a case from aluminium or thin steel gauge sheet the nibbler as mentioned above is essential, as are a selection of files from large bastards to small rat tails.
In addition a small metal brake (folder) is invaluable too. I have one of these for doing jobs up to 450mm (18") wide. I've used it for panels, scratchbuilt RC model tank chassis, repro vintage vehicle parts and other things.
https://www.ebay.com/itm/18-x-16G-Steel-Sheet-Metal-Bending-Brake-Folder-Bender/392677598516
Here's a similar one [url]https://www.kakaindustrial.ca/products/w1-2x460-18-inch-mini-sheet-metal-bending-brake
[/URL]
They are cheap generic Golden Dragon tools. In addition you just need to supply a couple of G-clamps to clamp the metal you are folding between the top steel bar and the frame. I have mine bolted down to a portable bench.
You can score thin sheet metal with a box cutter, then bend it to make it snap off. Usually you have to score it multiple times. Blades will easily drift off the beaten path so you need to have a solid guide (something hard like steel). And work slow.
Or you could use tin snips, but you tend to deform the metal. You can also cut with a fiber wheel attached to a dremel. For any sort of small scale sheet metal work a small drill is absolutely essential. Black and Decker makes a good one with variable speed. You can get it at target, 30-35$.
Harbor Fright sells a small bending brake for under 40$ I think. You can sometimes get away witj c-clamps and pieces of 2 x 4 or similar. You'll probably create more scrap using improvised tools. But if you're careful and watch lots of videos say maybe you'll luck out.
Metal craft is involved but rewarding. Figure on spending a bare minimum of 60$ just to get outfitted.
This lends itself much more readily to brass and copper, but you can mask off areas and etch cuts into metal. If you can't go all the way through, you have a channel where it will bend much more easily. For instance ferric chloride will not eat through clear packing tape. With steel I don't know if this is possible. Or aluminum.
I'm sorry I'm not an S-100 user so not quite in the same set of needs, but I have done a bit of case building. There's such a large range of ways of going about it that it's not easy to answer definitively.
You can sometimes get sheet-metal places to pre-cut panels to particular rectangular sizes much more cheaply than getting custom shapes cut, if you're lucky in your choice of supplier. Get that right and you can reduce your cutting to just a few corners, making it easier to tackle with limited hand tools such as a jeweler's saw/piercing saw. Or even a hacksaw, for some cuts. However you do it you'll need to hand-file.
tipc is dead right about bending brakes being a good tool for efficient, neat work - though if you get a low-end one you should expect to patiently check the alignment of the tool before it gives good results. I have seen a few that were not quite right out-of-the-box. It's not difficult. However, it might not be worth getting one if you won't get much more use out of it. I am a bit more optimistic about bending sheet metal with wood and clamps and gentle glancing hammerblows than tipc seems to be, but maybe my expectations of quality are lower. To be honest I am more of a woodworker than a sheet metal guy but I think it's worth picking a material and technique that gives the impression or feel you want for your project, even if it means a steep learning curve, as I think it's hard to love a project in a case that seems wrong for it.
I would say if you buy one larger tool, make it a drill press or bench drill if you don't already have one. Combined with a centre punch you can get every hole dead-on and it makes a world of difference to how professional the result can feel. I even managed to drill a fairly even ventilation grille with one once... don't try that by hand. You can also chain drill metal, saw down the resulting line and then file it all smooth... not efficient but a reasonable expedient for a one-off need.
Really everyone in the world should own a drill press. You can get a cheapo for under 75$. The Wen unit which costs a bit more then the rest was reviewed on youtube and was said to be a cut above. If you can justify the outlay. I want one very badly, but I'm keeping my expenditures and number of items I will eventually have to lug around to a minimum. I do have a small Austrian made milling machine, which could function as a drill press. But despite being "small", it's heavy enough, and was one of the items that furnished me with a femoral hernia some years ago. IOW it's sitting on the garage floor in a non operational state currently.
Craigslist and local ads could be a good place to find a dp for sometimes 25-40$. Great tool to have.
tipc - yes, you can get a cheapo drill press for under $75, but it should probably come with a warning label along the lines of "once you get the hang of this, it carries a significant risk of causing upgrade cravings"... my experience was that the bench drill gets more regular use than other tools and so it's more worth having a nice one... so maybe I owe bifo86 an apology for what this might end up costing. (Or bifo can give me a slap for telling what's already well known :-) )
Sad to hear about your injury and your mill (Emco?) stuck on the floor. If it's the kind of machine I'm envisaging, it's a whole different ball game compared to a bench drill, even a big one. I hope you find a friend who can help you get it on a table and set up.
Looking back at the original post, bifo86, I'm not quite sure I read you right the first time, sorry - if you just want to buy the Hammond case and make holes in it for keyboard and connectors, you may not need to do any sheet metal bending, but I fear cutting out the keyboard hole is going to be a bit stressful to do to a relatively expensive bought enclosure however you do it. So I see your concern about cutting metal in a different light when I think about that. Do you know anyone who can laser cut you an acrylic keyboard surround so as to make the job of cutting the keyboard hole less critical? (that's something I would consider - and if you pick a nice contrasting colour it could look fairly classy)
I hate to swerve from the op's subject a tad, but I've had a project that's been brimming around the edge of the pot for a long time. Yes, you guessed it, a drill press. A small one though, more suitable for modelmakers and "sensitve" drilling. It's a project in the old Projects in Metal magazine. Of course you need machinery, at the minimum a lathe. But I've skimmed the article a few times and there's nothing terribly complicated iirc. He even employs a kludge to implement the downfeed rack and pinion.
Oh then there's the Cowell's mini mill. "Reassuringly" expensive, but if you took a gander at the thing, there isn't a heck of a lot to it. It's a living doll. And if anyone else is interested in building a mini mill like that, pm me. Maybe we can conspire.
http://www.cowells.com/vmm.htm
Castings, if you chose to go that way, could probably be produced for 200$ or so. Given you choose the right foundry. But you have to supply the patterns.
As an aside this got really good reviews on Amazon (and about the same price):
https://www.homedepot.com/p/WEN-8-in-5-Speed-Drill-Press-4208/204853910
I'm tempted, but am likely to hold off. Really itching to try out some ideas about building a small (really small) metal cutting lathe from common stock, mostly alyminum (and steel). Hell I'd like to build a makeshift drill press, but there's likely little money to be saved.
What I should do is set up my mill and try the "ideas" with that. Then eventually attempt to repeat it with a dp.
FWIW, I have a small attachment for my Dremel that looks like a drill press. The drill motor mounts vertically in the attachment with a small rotary knob on the side to raise and lower the thing. Can't remember the last time I used it.
Yes they make larger ones to take say a B&D 3/8" vsr pistol style drill also. I actually saw one on a russian video they from the looks of it was very beefy. You can get away with anything, you can even mill (think of routing in metal) on a standard table top drill press and graduated milling-drilling table bolted on. You juat have to work very slooooooow. And the finish will leave something to be desired.
I'm a little wary of milling on a table top drill press. Some people clearly have managed it, it's not impossible. I admit I've done it myself on really soft metal. But it is a complete crapshoot as to whether you get away with it, or damage the machine, or get maimed by flying metal when something lets go. The bearings aren't as good at coping with side-load, the quill doesn't really support moving the tool down by a controlled increment, and there's no drawbar to keep the chuck in the taper. It might get you through one particular problem if you're careful and lucky, but it seems a bit of a last resort to me.
Even without milling, a cross table with graduated handwheels can be a fairly handy thing to have on a drillpress if the press is big enough (and you don't have a mill for the occasions where you need to coordinate drill). That said, I have one and now rarely use it. If it's not the main way you drill, it rather gets in the way - once I got the habit of being scrupulous about laying out my drill hole locations with scriber and dividers and punch, it seemed less relevant.
On one of my hard drives I had photos of homemade mill (if youb will) using various Taig and Sherline components. It was actually a company making th3 mill. I've searched for the site since but it hasn't turned up. It was a nifty little contraption. Many such machines, and more robust, have been concocted from "standard components". A particularly exciting area of development to me. I guess this is on account of Dave Gingery's Build your own Metal Workshop from Scrap series falling in my lap when I first decided to get into this stuff. "The Metal Lathe", the 2nd book in the series, the first being The Charcoal Foundry, is must reading for anyone looking to understand machine tools imho.
I do believe though that old Dave, who is good and dead and buried (an inside joke, you-d get it if you were, well, inside) may have stolen the idea from a Britisher named Mason who published a similar book. I've never read the Mason book, and he does not use aluminum castings, but both lathes are very similar looking. Could be a coincidence I guess. In any event DG added significant technique to his version even if it was the case.
Bud makes keyboard enclosures that you can use with whatever keyboard you want to use. Just need to cut out the metal to match the layout and then the computer itself can go into a a metal box big enough to hold all the guts.
Keyboard enclosures: https://www.budind.com/view/Small+Metal+Electronics+Enclosures/Keyboard+Enclosures
Believe that I mentioned that at #3.
The trouble with doing milling with a drill press is that the quill and bearings aren't engineered for substantial side loads, which puts a limit on what these can do. Of course a real vertical mill can do both drilling and milling, but that's what it's engineered to do. If you're willing to do a fair amount of "tweaking", the small lathes and mills from Harbor Freight can be good deals--there's plenty on the web about this.
I advise against buying Harbor Fright lathes and mills. If you can pick one up used for 300 and change then well maybe. There are often still deals on older machines out there. You really need to know someone in the know before buying anything. Right off the bat with these 600$+ lathes is the bearings are rattling around with fine steel grit that was never cleaned out. So you have to pull the spindle and bearings. Clean and repack. Oi. You used to be able to get a Sieg 7x12 for 300$. Ok that was 15 years ago, but the price had to double?
I bought an 8" (not a tupo) South Bend lathe for 300$ recently. It needs a little tlc and doesn't have any extra change gears but has a chuck. I was xontemplating how to fenagle the missing gears at low cost. But other concerns push that on the back burner.
You can buy a stripped Taig lathe for ~175$ and fenagle the rest. It's pretty lite duty but may actually give you a better finish in mild steel then a HF jalopy. Sherline machines and accessories are well made but lite duty. Prazi is a name I like, but I will not deal with the current US distributor. Ok maybe if I needed a chuck key. That guy is a real triple acecola. Prazi are pricey, but often fairly cheap 2nd hand.
I recall when Taiwan was getting into the gray iron machine tools racket. They tried to duplicate the US stuff and the results were actually pretty good. I've still got a drill press by some long-gone Taiwanese manufacturer that I bought about 35 years ago. Still going strong; no runout in the spindle to speak of. I was ridiculed by a friend who bought Swiss machine tools. Yes, the finish on those was pretty darned nice, but he paid a hefty premium for that.
If you've got money to burn, there are some very fine tools out there. If you're on a budget, maybe that's out of your reach. Availability of used machine tools varies greatly by location. If you live in Ohio or Michigan, you're in pretty prime territory. If you live in Wyoming, maybe not.
