CP/M User
Hello,
Since I've been leaving clues all over this message board, everyone
probably knows who I 'am by now!
Oh well, If you don't read the regular newsgroups (or this) you may
not have!
I merely have an Amstrad CPC computer (also couple of DOS emulators
running for it on a IBM compatable), play around & program with CP/M
on that, also play around & do some programming in CP/M-86 on the IBMs.
Main programming language I use is Turbo Pascal. Although I like to play
with the low-level code it allows some support for. Since Turbo Pascal
was what I started working with on my ol' IBM XT, it's what I've
seemed to have learned best, as an added bonus it's available for the
Amstrad CPC (under CP/M) & CP/M-86. In programming (using Turbo
Pascal) I have only done a little porting between these systems. The
simplier the better (although I like to bring in some routines which are
highly unportable, but it's the best way of producing what those machines
are capable of!)
Regards.
not have!
are capable of!)
Regards.
