Here's a nice article that popped up on the web today about Windows XP . . .
http://www.makeuseof.com/tag/windows-xp-wont-going-away-anytime-soon/
| VCF SoCal | TBD, 2027, | Southern CA |
| VCF East | TBD, 2027, | InfoAge, Wall, NJ |
| VCF Latam | TBD, 2027, | Bahía Blanca, Argentina |
| VCF Pac. NW | TBD , 2027, | Tukwila, WA |
| VCF Southwest | TBD, 2027, | Westin Dallas Fort Worth Airport |
It's not even like the old days when new versions brought new useful features. These days every time I encounter an "upgrade" I have to ask myself "what have they taken away now?".
Of course every one else complains about the "bloat".....
.. read the article, interesting, but having watched some one try to use XP on a minimum spec machine fond the assertion it will run on lower spec hardware some what amusing.. It might install, but pretty useless... One of the things that have changed is that Microsoft now quote minimum specifications that are "usable"...
How low is low? I run XP on a PIII (1.4 GHz) and it does fairly well, browsing not with standing. Not too bad with Firefox however. A few years back, maybe 2002/3, I had an IBM Thinkpad T22 which came with W2K. Somehow or another, I was able to upgrade to XP, and it ran pretty good. The net wasn't near what it is today and a person had a little more patience with it. On the other hand, I have a Pentium D setup (single core) and it barely get along. The beauty of XP is that it's rock solid and a great gaming platform - no 'gotchas' The only problem you might encounter is maybe an errant third-party driver for this or that.
Take away?!?! I agree but I see they add drivers to Win8 and 10 that AREN'T necessary but causes fans on laptops to run at JET speed. When they're disabled the fan resumes normal speed. I've tried adjusting power settings but until I disable the driver it keeps going. They keep installing an AMD Radeon HD graphics driver on my laptop that's NOT needed. Bloatware STINKS!
Sorry for my tangent.
Well, I agree, that's pretty low. You can get XP to run on a 486/133 for sure if you install it first on at least a Pentium machine's HD. But that's all bar bet stuff. The point is, XP runs real nice on later day machines. The major catch is if you can snag the XP drivers for your particular chipset.
Pentium Ds are dual core chips, hence the "D". They're not true dual core designs though, it's basically a pair of Pentium 4 dies under the heatspreader. Celeron Ds are single core only though.
Hello Dave.
Neh not using he show/hide tool. I'll investigate it more. Have you used it ok?
Thanks
Actually, XP won't run on a 486 at all. Even if you install it on a Pentium machine and migrate it over, it still won't run. 486 CPUs are missing CMPXCHG8b and CPUID, which are required for XP to work. You can get XP to run on a 486 machine though if you install the 62 or 83 MHz Pentium Overdrive chip. I can't recommend it though because it's painfully slow, I know because I've done it before.
Another chip that XP might run on is the Cyrix Cx5x86, because that chip is essentially a gimped Cyrix 6x86. I can't test this though because I don't have one or a motherboard that would accept one.
Another hurdle you have to overcome is that you need 64 MB of RAM minimum if you want to actually install XP on the 486 machine, which many early 486 boards can't get anywhere near. Later 486 boards with PCI slots and 72 pin SIMMs can usually get up to this amount. I had a PC Chips motherboard that could go up to 256 MB (4 x 64M 72 pin SIMMs.)
I was under the impression new CNC rigs had the ability to get files directly from CAD (something an old controller running DOS can't do).The mention of SCADA in the article was interesting, but how much does "real work" depend on Windows XP? For example, are you aware that more than a few CNC rigs run on CP/M or MS-DOS? And the reasons are eminently practical. You can pay $250K for a new EDM rig, or buy a used one for less that $50K. Both will get the job done and have parts available, so which do you choose? Heck, I've seen some rigged up running from PCs hooked up to the machine's paper tape input that are still going strong.
I sometimes wish the consumer market had the same level of practicality.
